  #1
Old October 11th, 2003, 09:19 AM
Rob in Gabon Rob in Gabon is offline
Default Mercury starter - can i weld the bendix
We are in Gabon West africa and have a 1 year old 90hp 2 stroke mercury outboard- the starter bendix engages but then stops spinning as it would appear that there is a clutch/bushing of some form as the drive nut comes off the top of the worm gear( into the back of the bendix gear) to allow the starter to spin free of the bendix gear- it will take several weeks to obtain a spare in our location and cost over $600US can this bendix clutch / bushing be removed or repaired in the bendix - is it opossible to weld the nut that runs on the worm gear to the actual gear so that it will still drive the flywheel and disengage as required when running?? any advise would be great- Rob in Gabon
  #2
Old October 11th, 2003, 09:58 AM
rodbolt rodbolt is offline
Default Re: Mercury starter - can i weld the bendix
Rob hello from the states I am not positive I understand your delima. you say the drive engages the flywheel. does the lower part of the drive spin and the toothed part not spin after engaugemnt? I welded the upper part of the drive to the lower on a sport jet 90 to get the people through a weekend. the drive has a 2 part with a rubber bushing between them. if the get wet or over oiled they can slip. usually once they start slipping they usually wont stop. repost and reword the description so I can get an idea of what is going on. good luck and keep posting.
  #3
Old October 11th, 2003, 02:48 PM
greasemonkeyozi greasemonkeyozi is offline
No dont weld it. Give me your email address and I can find you one used.
  #4
Old October 12th, 2003, 07:34 AM
The Marine Doctor The Marine Doctor is offline
Is it the shipping that makes the price so high?The bendix sells for $40.00 here in Canada.$350.00 for the entire starter.TMD
  #5
Old October 15th, 2003, 07:00 AM
Thank you all for the comments- we are situated right on the edge of the second largest rainforest on earth, with import duty tax and shipping here adding nearly the same cost again to anything that you buy here and thatÂ’s if it actually what you ordered or indeed actually arrives.So until we can get someone to bring a spare in i was looking at making a temp repair - technically is their any issue with bypassing the rubber bushing as Rodbolt suggests that he did to get him over a weekend (thanks Rodbolt) or will i damage the starter in some way that i will have to replace the entire starter and not just the drive gear? Appreciating your advice - Rob
  #6
Old October 15th, 2003, 05:53 PM
DJENAN DJENAN is offline
I WOULD WELD IT AND THEN IF U DO STUFF IT UP ORDER ANOTHER ANOTHER STARTER.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
bad starter? bendix is spinning shelikesit Mercury & Mariner Outboards 0 October 9th, 2006 04:58 PM
Replaced bendix on Starter on Mercury Ricky&Lisa Mercury & Mariner Outboards 1 September 9th, 2003 10:10 AM
merc 650 starter bendix RIDEPATE Mercury & Mariner Outboards 1 June 22nd, 2002 03:30 PM
starter bendix V156 Other Outboard Brands 7 June 19th, 2002 02:06 PM
starter bendix V156 Other Outboard Brands 1 June 17th, 2002 10:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
