  #1
Old October 5th, 2003, 05:27 PM
big_johnst big_johnst is offline
Default 85' 55HP Mariner Starting Problems
I have a 1985 Mariner 55HP motor that is not starting properly. This is one of the Mariner motors that was made by Yamaha. The motor starts fine most times but ocassionally will not start after it has been sitting a while. An example would be, like after being anchored at a hot fishing spot for an hour or so. It will grind down like the problem is a dead battery. Changing the battery to a fresh one doesn't help. The old battery will test good. To get it going, I have to rope start it. If I shut it off it will usually restart. Some times it will go 10-15 times and work fine and then it may not start 3 or 4 times in a row. I would like to check out the entire charging/starting sytem. I have seen some replies to other topics describing how to do this. Anything special that needs to be done for this motor. I have been unsuccesful in locating a shop manual for this motor. T he C-55 Yamaha seems to be pretty much the same. HELP !!
  #2
Old October 7th, 2003, 11:30 PM
SpinnerBait_Nut's Avatar
SpinnerBait_Nut SpinnerBait_Nut is offline
A true iboats friend
Default Re: 85' 55HP Mariner Starting Problems
Oak John, if you check at the bottom of this page and click on repair manuals, you will find a Clymer Part# B714 that covers 1976 to 1987, 2 to 200 HP engines for Mariner.
__________________
http://banners.wunderground.com/weat...tlettsburg.gif
http://www.frappr.com/iboats
"JUST KEEP ON, KEEPING ON"©
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
  #3
Old October 8th, 2003, 03:45 AM
Thanks for the tip on the manual. I have actually seen this one before. It does not specifically cover my motor. (It is really a Yamaha motor) Anyway, I have found a yamaha manual at the local library that pretty much covers everything.
  #4
Old October 8th, 2003, 04:11 AM
okie dokie.
__________________
  #5
Old October 9th, 2003, 04:21 AM
The problem was a bad battery.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 75 starting problems jmburock Mercury & Mariner Outboards 18 June 16th, 2007 12:48 AM
starting problems with mariner 90 snookered171 Mercury & Mariner Outboards 7 November 25th, 2005 12:04 PM
MARINER 60 STARTING PROBLEMS dadowales Mercury & Mariner Outboards 2 June 10th, 2005 11:38 AM
1969 E/J 55hp starting problems psuguy131 Johnson & Evinrude Outboards 10 May 24th, 2005 01:23 PM
55hp johnson starting problems maintain-man Johnson & Evinrude Outboards 1 April 18th, 2005 05:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
