  #1
Old August 28th, 2005, 11:09 AM
dave524's Avatar
dave524 dave524 is offline
Default New Boat Questions
Hello all. I just purchased a used 17ft Blue Fin Sportsman boat. It has a Force 50hp outboard on it. I took the boat out yesterday and all is great. With full gear and 2 adults on board, the boat gets up on plane, but the bow seems to be high. Do I need to play with the manual trim or a different prop to correct this ? Also how do I find the recommended WOT RPM for this engine ? And finaly, anyone have a Blue Fin boat? How are they ? Thanks for the help. This forum seems very wise.
  #2
Old August 28th, 2005, 03:42 PM
AJ168 AJ168 is offline
Default Re: New Boat Questions
Congratulations on your new boat. Playing with the engine's trim could help lower the bow. Drop it down a notch and then test it. Play with it until you find where the boat rides the best. If the bow still seems to ride high, then you could go buy a hydrofoil or trim tabs. You'll get a lot of different opinions on this. Many times, you can find WOT RPM's on prop manufacturers web sites, although you may have trouble finding this because Force is no longer made. This is how you detirmine if the boat/engine is propped correctly. If the RPM's are below specs then you need a lower pitch prop, if they're above, then you need a higher pitch prop.
  #3
Old August 28th, 2005, 03:43 PM
dtherrien dtherrien is offline
What year is the boat and motor? There should be a plate or decal on your motor...it could be under the cowling...it will tell the year and rec.rpms.What rpms are you turning now. We need more info first, before telling you what you should do.And you can get a service manual for the year motor.
  #4
Old August 28th, 2005, 05:26 PM
dave524's Avatar
The year is 1988, I have to look for the motor plate info for you. Can I use a car tach and if so, where do I hook it up to . Thanks again !!!!
  #5
Old August 28th, 2005, 08:41 PM
roscoe's Avatar
roscoe roscoe is offline
Give us the motor model number.It is only found on the id tag located on the side of the transom mounting bracket. The recommended rpm range did vary over the years, between 4500 and 5500 rpm. So to be more specific, we need year/model info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New boat questions ferrariman Boat Topics and Questions (not engine topics) 6 March 19th, 2006 09:30 AM
New boat questions wormgear Boat Topics and Questions (not engine topics) 1 April 1st, 2005 01:04 PM
Converting ski boat to fishing boat... Deck finishing questions... Florida John Boat Topics and Questions (not engine topics) 5 February 6th, 2005 03:29 PM
First Boat Questions (Boat Power & Trim) da C was vicious that day Force & Chrysler Outboards 6 July 17th, 2003 09:24 PM
New boat questions????? masterp Boat Topics and Questions (not engine topics) 24 January 13th, 2003 03:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
