  #1
Old September 19th, 2003, 09:14 AM
walleyechaser walleyechaser is offline
Default Flywheel removal 84 mariner 90hp
What type of puller do you need to remove the flywheel? Or can you remove the 6 bolts markit then remove the flywheel to replace the stator?
  #2
Old September 19th, 2003, 10:39 AM
The Marine Doctor The Marine Doctor is offline
Default Re: Flywheel removal 84 mariner 90hp
There is a special tool required to remove the flywheel. If you take out the 6 bolts and do not get the flywheel back together properly..the engine will not run. You will still be left with removing the hub assembly anyway.TMD
  #3
Old September 19th, 2003, 07:27 PM
Do you remove 4 of the bolts and use them in conjuction with a puller to remove the flywheelIs the puller available to be purchased?
  #4
Old September 19th, 2003, 07:40 PM
Skinsk Skinsk is offline
The puller threads down the big hole on top of the fly-wheel, then bolt is threaded down anther hole in the center of the puller, which pushes on the crank (actually on an aluminum spacer that comes with the tool so you don't muck up the crank), and pops the fly-wheel up... (usually with a pop..)It is a mercury special tool, and can probably be purchased at your local deal, and maybe even online somewhere..Scott..
  #5
Old September 19th, 2003, 08:38 PM
Can you remove the 8 bolts around the hub and remove the flywheel after you mark the hub for reinstall?
  #6
Old September 19th, 2003, 08:55 PM
Why is it you need to remove the flywheel?TMD
  #7
Old September 19th, 2003, 09:01 PM
To replace the stator
  #8
Old September 19th, 2003, 09:02 PM
Yes..then I believe you will have enough room to pull the stator over the hub...MAKE SURE You mark the fly wheel.TMD
  #9
Old September 19th, 2003, 09:07 PM
ThanksThis seems a better way to go instead of buying a special puller to remove the flywheel
  #10
Old September 19th, 2003, 10:51 PM
ronmold ronmold is offline
Flywheel is very well balanced, if you pull the bolts and mark it, when you re assemble you will notice play in the the bolt holes before tightening them. pull the plugs and use a dial gauge or some type of reference point and spin the shaft w/ a big socket to be sure the 'wheel is centered before final torque. Off a few thousanths @ 5 grand can make bad crankshaft-breaking vibration.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Flywheel removal 1988 100HP Mariner Special Tool w2much Mercury & Mariner Outboards 2 May 28th, 2006 01:15 PM
flywheel removal? hisey1 Johnson & Evinrude Outboards 13 March 2nd, 2006 04:59 AM
Flywheel Removal busboy Mercury & Mariner Outboards 10 May 30th, 2005 03:34 PM
removal of flywheel remant333 Mercury & Mariner Outboards 13 July 30th, 2003 06:49 PM
flywheel removal tonym302 Mercury & Mariner Outboards 6 November 16th, 2002 05:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
