  #1
Old September 17th, 2003, 06:46 PM
walleyechaser walleyechaser is offline
Default 84 mariner dies above 2200 rpm 90hp
I have replace one switchbox because 2 and 5 were not firing. All of the plugs are now firing when grounded to the engine.I have replaced the fuel hoses back to the tank. I have rebuild the fuel pump and new floats and needle and seats.I have checked the resistance of the stator with the following results red or red/wh to ground 143 ohms blue or blue/wh to groud 6350 ohms. Bias resistance to ground 13500 ohms and 14500 ohms. I have 3-4 psi pressure when cranking on the fuel pump. The timing is 1 degree at cranking and 20 degrees at WOT. All of the coils check ok with resistance. The stator wires to the rectifier read 0.8 ohms. Where do i go from here.
  #2
Old September 17th, 2003, 06:47 PM
Default Re: 84 mariner dies above 2200 rpm 90hp
I mean plugs 3 and 5 were not firing
  #3
Old September 17th, 2003, 09:08 PM
Skinsk Skinsk is offline
Get youself a Direct Voltage Adapter (DVA available from Merc for about $60), or a Peak Reading Adapter, and check the voltage coming from the red wires to ground.. Those are the high speed stator wires, and should be around 50 volts at cranking speed.. According to mercury, the ohm's tests are really not usually helpful in finding faults with their ignition systems. They'd rather do voltage output tests, and then use the Ohms tests to confirm a problem..Scott..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
93 Force 90HP dies when in water mrobertson Force & Chrysler Outboards 5 October 1st, 2006 02:49 PM
84 90hp vro pulses and dies draino Johnson & Evinrude Outboards 0 July 28th, 2005 04:34 PM
1991 90hp mariner and 1994 115hp mariner JC1933 Mercury & Mariner Outboards 4 January 12th, 2004 09:38 AM
1991 90hp mariner and 1994 115hp mariner JC1933 Force & Chrysler Outboards 1 January 11th, 2004 06:38 PM
1995 90HP Johnson dies hot Rambler Johnson & Evinrude Outboards 6 September 12th, 2002 06:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
