  #1
Old October 9th, 2004, 06:41 PM
Searun1 Searun1 is offline
Default aluminum vs. stainless prop question
Sorry guys but I have a prop question...I tried using search but did not find what I was looking for.I have a 13.25x17 standard Yamaha aluminum prop on a 90 HP '05 two stroke. The boat is a fairly typical deep v runabout at 16' and fiberglass.I was thinking about an upgrade to a stainless prop and am a little confused. I think I read on this board that the same diameter/pitch prop is different between ss and aluminum.Would I look at a 13x19 or the same size ss? The boat is mostly used for salmon fishing here on Puget Sound with the occasional wakeboard/skiing excursion.Any advice would be greatly appreciated.Searun1
  #2
Old October 9th, 2004, 07:15 PM
bluewater19 bluewater19 is offline
Default Re: aluminum vs. stainless prop question
What are your RPM at WOT?If you are within the manufactures recomended rpm range then use the same size in stainless. You might see a little more topend but not enough to go up 2 inches of pitch.
  #3
Old October 9th, 2004, 10:49 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Asuming your RPM is in the top of the max range, I would suggest a Stiletto 13.25X17 if dead-set on a prop-swap.Raising the eng. on the transom can add measurable performance as well.I have been in your shoes with a simular application and went from a 15 pitch to an 18 pitch just by eng. heigth adjustment/mounting location, and actually gained RPM slightly, and best of all, I added 9MPH to my top-end.If you want to play, we can tell ya how....
  #4
Old October 11th, 2004, 08:35 AM
Thanks for the advice. I rarely get to push the speed on this boat anyway due to water conditions. I am getting 5500 at WOT with the aluminum so I will likely go the same size in stainless.I really dont need high performance, just want reliability and better economy. It is a fishing boat for the most part. Thanks again guys.Searun1
  #5
Old October 11th, 2004, 08:42 AM
walleyehed's Avatar
Here's an Idea....If you raise the eng., lower drag and are able to spin more pitch at the same RPM, which equates to faster speeds, yet when pulled back you would be attaining the same speed at lower RPM, creating substantial fuel savings....????Hummmmm.......More'in one way ta skin a cat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum to stainless prop; lost WOT rpm agrazela Mercury & Mariner Outboards 23 May 10th, 2004 04:10 PM
Stainless or Aluminum Prop? Rushin Non-Repair Outboard Discussions 23 January 6th, 2003 06:08 PM
stainless vs aluminum prop h2oTherapy Non-Repair Outboard Discussions 4 May 6th, 2002 05:22 PM
Prop, aluminum vs. stainless gobydon Mercury & Mariner Outboards 2 October 11th, 2001 01:40 PM
Aluminum Vs Stainless Prop fritchey Johnson & Evinrude Outboards 4 August 23rd, 2001 10:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
