I have a 1977 Merc 50 4 cyl. mounted to a 14 ft. fiberglass skiff. It was recently worked on to change exhaust plates and carbs de-gummed and supposedly timed. I have a sting-ray fin attached to minumize porpoising, so here is a couple problems I encountered upon running this motor on this boat, oh yes and it has a 14P prop.<br />The take off is atrocious the motor seems to bog down upon full acceleration on take off and after a while it starts to rev up and gets up on plane and when I back down on the throttle a bit it loses its rpms and goes to almost idle speed but it is actually around half throttle on the stick,then bogs down again , until I slam it to full throttle then it starts its slow climb in rpms until I hit plane again. I did a compression check on the cyls and 1 2 and 4 have 120+ and # 3 has 100, which I was told was all in tolerance. So why is this motor bogging down on acceleration and taking so long to build the rpms up? The bow is extremely light on this boat, so could this be just a weight problem, that is the motor too heavy for the boat. I figured that the 50hp would make the boat jump out the water not set it down bog or cavitate whatever its doing. please help.<br /> Thanks
