Re: damaged pistsons
What has happened is the cylinders in question has run lean. Lean fuel burn causes the exhaust gasses to get really hot and melt pistons. That's why when you pull the pistons, you'll find the exhaust side of the pistons melted and the intake usually not. To repair this, more than likely you will need to bore the affected cylinders and replace the pistons. The pistons with the needle bearing stuck in them has allowed the bearing to come out the side of the piston and get into the cylinder. You will probably find some bad rods, lots of bad bearings. These inline sixes were famous for doing this.
