  #1
Old September 1st, 2003, 07:47 AM
paulgp6022 paulgp6022 is offline
Default Paint touch up on mercury??
Hello, can I use black fingernail polish to spot touch up a nick on my lower unit? The nick is about the size of a grain of rice. Finger nail polish is enamel, so it is strong stuff and should work right? Thanks in advance.
  #2
Old September 1st, 2003, 08:08 AM
The Marine Doctor The Marine Doctor is offline
Default Re: Paint touch up on mercury??
Nice rig. Yes you can paint it with that.TMD
  #3
Old September 1st, 2003, 08:11 AM
Thanks for the reply and the compliment!
  #4
Old September 1st, 2003, 02:51 PM
andrewkafp andrewkafp is offline
There'll be quite a few more of those little knicks as she gets older.... But.. seriously, if it has gone back to the aluminium, nothing will stick to it, unless you use a zinc etching primer. I sprayed my L/U with various types of Auto paint, it just comes off with the abrasive sand and water flow.
  #5
Old September 1st, 2003, 03:06 PM
I know.. it is a constant battle against the elements and father time..
  #6
Old September 1st, 2003, 07:18 PM
Skinsk Skinsk is offline
Mercury sells "phantom black" spray paint that seems to stay on fairly well. Just clean the area with Laquer thinner, and give it a good dusting. But it won't stay on forever..Scott.
  #7
Old September 2nd, 2003, 09:37 AM
wes_moore wes_moore is offline
I got a cheap can of black spray paint and it worked great there wasn't a difference between colours I used some clear laquer to make it shiny. the can said odds and ends on it and I would recommend it for mercury's----------Wes
  #8
Old September 4th, 2003, 05:21 PM
If you really want to do a good permanent (within reason) job. You need to look up the subject and you will find that you need to sand the affected area back to metal, use an "Etching" primer, which sticks to the alloy, and then you can paint with the Merc black. This top coat is just Nitro or Arcylic laquer. It's that etch paint that provides good adhesion. Painting alloy is always difficult, as people with Aluminium boats will tell you. It's all in the undercoat. 'ave a lookat dis.. http://continuouswave.com/maintenance-logs/paintSkeg/
  #9
Old September 5th, 2003, 10:50 AM
greasemonkeyozi greasemonkeyozi is offline
Good lord, I should use this on my whole lower unit, mine looks like a zeebra or something...
  #10
Old September 5th, 2003, 12:19 PM
KCLOST KCLOST is offline
I'll tell you what I will do for anyone wanting to paint a lower unit...This is all you have to do...Take the lower unit off,Remove the water pump assembly,Remove the drive shaft,Remove the shift shaft, Remove the propeller,Remove the gears,Remove the Trim Tab,Not necessarily in that order.......Basically strip the whole thing down until all you have is the housing of the lower unit. make sure you have cleaned out all the gear lube and flushed with solvent, I can't have any of that left in there...Piece of cake!!!!!Then send the lower unit to me and I'll place it in a burn off oven and burn off all the old paint. Then run it through a five stage cleaning process, and powder coat the housing with a Gloss Black Hybrid (epoxy/polyester) good hardness and UV resistance, cure it in a 350 degree oven for about 20 minutes and that baby will be 10 times better than it ever was even brand new. All you have to do is follow those easy steps and I guarantee a beautiful finish that will nver flake off (within reason of course) Free of charge...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lund Red Touch up paint Jeff_reeder Lund Boats 2 January 25th, 2006 03:06 AM
Paint touch up question nightvision Boat Topics and Questions (not engine topics) 4 July 9th, 2005 11:47 AM
Honda touch up paint jjdoro2 Honda & Tohatsu/Nissan Outboards 2 June 22nd, 2004 12:28 PM
Lund Red Touch up paint Jeff_reeder Boat Topics and Questions (not engine topics) 1 May 7th, 2004 11:24 AM
Mariner touch up paint!! waddell Mercury & Mariner Outboards 1 October 28th, 2003 03:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
