If it is the fast beeping oil alarm then it could be the oil pump itself. This is the biggest Mercury/Mariner vice, the plastic gear crank driven oil pump which can strip out without any warning. My 150 just stripped out the gear with only 50 hrs on it, and the powerhead had to be replaced with me shutting off the motor immediately up on hearing the beep.
Better get it checked out.
TM
