  #1
Old August 28th, 2003, 06:49 PM
daritzzz daritzzz is offline
Default Is there a choke on a mercury EFI 150??(98)
It's not like the carb version, efi has no choke-throttle.Probably it will inject more fuel(elektronic)but that's what I want to know and if you need to push the choke(key)?maybe it chokes automatic(temp sensor)ps does anyone has an owners manual for this engineGtzz tirett
  #2
Old August 28th, 2003, 11:16 PM
naketa naketa is offline
Default Re: Is there a choke on a mercury EFI 150??(98)
is a automatic choke when you turn the key push the key in to choke
  #3
Old August 28th, 2003, 11:31 PM
Thanks :o
  #4
Old August 29th, 2003, 12:15 AM
roscoe's Avatar
roscoe roscoe is offline
Tirett, I think "naketa" was asking a question, not giving you an answer.You can get an owners manual at a mercury dealer. Or you might be able to order one here: http://www.mercurypartsexpress.com/P...phome.asp?CID= I would check to see if they will ship to Belgium before I ordered one.
  #5
Old September 1st, 2003, 08:26 AM
Thanks Roscoe, I will order a
  #6
Old September 1st, 2003, 08:32 AM
Roscoe, I will order a manual(they ship to Belgium), but i was thinking that naketa gived me an answer.I'm sorry for that Allthough I do not understand his question maybe you can explain naketa's question to me GtzzzTirett
  #7
Old September 1st, 2003, 11:40 AM
roscoe's Avatar
After read some of naketa's other posts, I believe he is new to boating. I think he was asking if a keyswitch activated choke, would be considered an "automatic" choke.I have used an efi outboard only once.It did not have a choke built into the switch.I believe the computer compensates for the air temp, engine temp, oxygen level, and humidity level, much like an automobile with efi.
  #8
Old September 1st, 2003, 12:25 PM
Hello Roscoe,I think it's an manual, automatic chokeWhen I turn the key, I can push it(standaard merc-control)When I push it while starting cold I believe it's choking, because the engine will run after first try.also without pushing the key, sometimes engine ran at first crank Allthough I don't really tried to figure it out.That's why I ask this question here.I've no manual from this engine :o Hope someone knows it here Thx Gtzzz Tirett
  #9
Old September 1st, 2003, 12:50 PM
clanton clanton is offline
The temp sensor provides ECM with engine temp signal, determines enrichment of fuel until engines reaches 90 degrees F. Temp sensor has to have clean engine ground. You only have to turn key to start.
  #10
Old September 1st, 2003, 07:59 PM
Cobe Cobe is offline
There is no choke. EFI uses fuel enrichenment; a choke accomplishes the same thing but, by reducing (choking) the air flow.
  #11
Old September 2nd, 2003, 11:17 AM
Thx guys,Now I know that I don't need to push the key.It's an automatic choke like a car efi.B.T.W. Great engine I love to fly Gtzz Tirett
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury choke lever Rick W Backous Mercury & Mariner Outboards 0 September 21st, 2006 01:28 PM
How does choke work on Mercury? paulgp6022 Mercury & Mariner Outboards 1 June 8th, 2003 06:45 AM
Mercury 7.5 choke Vahevala Mercury & Mariner Outboards 1 March 17th, 2003 10:19 AM
mercury sport jet No CHoke? acat600 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 August 2nd, 2002 10:02 AM
50 Mercury Only run on full choke. mann Mercury & Mariner Outboards 2 July 26th, 2002 06:36 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
