  #1
Old August 28th, 2003, 04:08 AM
olibass1 olibass1 is offline
Default 60 HP MARINER GAS LEAK
HELLO GUYS,I have a 1988 60 hp mariner that tends to leak gas when trimmed up and not running. I have been told that a small amount of gas leaking is normal on older motors by two different mechanics, but i don't know anyone else that owns an older boat with this problem. i know this isn't a carb issue because both carbs are brand new (not just rebuilt). I was wondering if the check valve in the fuel pump could be faulty? any help would be appreciated.
  #2
Old August 28th, 2003, 05:03 AM
greasemonkeyozi greasemonkeyozi is offline
Default Re: 60 HP MARINER GAS LEAK
Were exactly did you say the fuel is leaking? I have noticed that on my motor, propably on most, that fuel lines dont have hose clamps on the ends, just zip ties, they dont seal worth a flip. Its inexpensive and a good idea to add screw tight hose clamps on all your hose ends. I dont know if this helps your problem, but at least this can be good food for thought. Oh yeah, if you do decide to do this little job, while your at the parts store getting some hose clamps, buy a small inexpensive inline fuel filter to put on the fuel line somewhere.
  #3
Old August 28th, 2003, 06:51 AM
the fuel is leaking internally. it is pulsing from the spray nozzle inside the carb throat. it seems to only leak until the built up pressure in the line is gone. when the motor is tilted, the leaking fuel runs out of the carb & down the motor. hope this info gives you a better idea of my problem.
  #4
Old August 28th, 2003, 01:27 PM
canary48 canary48 is offline
HiI also have a Mariner 60hp 3 cylinder 1988 oil injected engine and have also noticed that when trimmed up fuel leaks, quite a large amount drips from the carb area of the engine but diffiult to ascertain where exactly. If I prime the fuel it leaks further, I have never noticed any fuel leaking whilst running so I would also be interested if the leak is a problem or just some kind of safety/overflow mechanism.Thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp 4 stroke Mariner fuel leak skategoat Mercury & Mariner Outboards 0 July 13th, 2006 11:59 AM
Oil and Gas Leak on 90hp Mariner Crappiefishing Mercury & Mariner Outboards 5 June 4th, 2006 08:17 AM
'91 Mariner 200hp performance / oil leak. RatherBFishing Mercury & Mariner Outboards 13 June 22nd, 2004 07:02 AM
Mariner 25HP Oil Leak! filfyfisher Mercury & Mariner Outboards 4 March 6th, 2004 04:01 AM
95 mariner 150 efi water leak ugalboogala Mercury & Mariner Outboards 1 November 5th, 2003 06:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
