  #1
Old August 27th, 2003, 02:52 PM
Biggerstaff Biggerstaff is offline
Default Mercury 1250 timing
I have heard several discussions on what the timing should be set at for the old inlines. Most of what I have found in the forum archives is usually specs from the direct charge outboards and nothing specific to the old crossflows. Could anyone confirm what the specs should be on my 1969 1250ss? And how to static time it? Thanks
  #2
Old August 28th, 2003, 02:59 PM
Default Re: Mercury 1250 timing
  #3
Old August 29th, 2003, 02:37 PM
  #4
Old August 30th, 2003, 02:18 PM
corm's Avatar
corm corm is offline
Hi Big,The timming is 34 degrees BTDC on that motor. It is best to set it on the water with someone you trust driving, or the safer way. Back the boat in the water till the cavationplate is covered and set the timming with it on the trailier. It will spray water so people may get mad at you. Also watch out so the prop doesn't hit the bottom or the ramp. If your launch ramps are to busy to do it this way you can do this. Pull all the plugs. Put the cyl no. 1 plug in the sparky and ground it to the port side of the motor. Shift the motor into F gear and open the throtal wide open. Turn the key to to on position. Check to see that you have ALL 6 plugs out. Turn the flywheel clockwise by hand while watching the white dot on the top flywheel. As it(or white line on side of flywheel under the dot) comes to the 34deg mark on the decal you will hear & see the spark jump the gap on the sparkplug. When this happens it is where your motor is timed at. It is changed by the spark adv screw on the plate in front of the distributor. If it does not spark at that point you will have to adjust the screw so it does. It is better to have it spark at 32 deg than 36 deg so error on the less advanced side with this motor. The timing decals are set up different on this motor so the 21deg timming that later L6's are set at means nothing with your motor, just in case your wondering about the numbers.
__________________
This is free internet advice.
Have Fun,
corm
  #5
Old August 30th, 2003, 03:24 PM
greasemonkeyozi greasemonkeyozi is offline
Can this type motor be timed with a standard timing gun and a shop manual?
  #6
Old August 30th, 2003, 08:01 PM
corm's Avatar
you bet that is why I like to run them on the water at WOT with a timming light. It is the most accurate way. Either on the trailier or smooth water. One more thing is that you can take an old prop and cut off about 1/3 of each blade to make a test prop which really makes it easy to set your motor up. The motor doesn't jump around then when you set it up on the trailier. One more tid-bit L6 Merc's run full spark advance with about 1/3 butterfly opening the rest of the throtal is fuel related only, so If you don't like the noise you can set it up at a lower RPM. Just make sure that you have FULL spark advance before you change anything.OOPs I bet you are talking about using the starter to turn the motor over with the plugs out to set the timing at home. Yep you can do that too. *Warning* on this method it is easy to drain the battery down and overheat the starter windings. *Bigger WARNING* it is real easy to run the battery down and wreck this CD type ing. sys. I never use this method myself on this ing. sys.Footnote; The 125hp Merc is the only Merc that has a mechanical advance that at WOT retards the timing a bit.
__________________
Have Fun,
corm
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 1250 pieperb Mercury & Mariner Outboards 14 March 9th, 2007 01:55 AM
1250 linkage hookup help 69GlassparMan Mercury & Mariner Outboards 9 May 22nd, 2005 07:21 AM
anyone know if these sparkplugs are for 1250? 69GlassparMan Mercury & Mariner Outboards 5 May 15th, 2005 07:40 PM
1969 Mercury Model 1250 Inline 6 85horse? How to start without controls? Joesnowmobiles Mercury & Mariner Outboards 9 September 18th, 2003 09:25 AM
Mercury 1250 JUDAH Mercury & Mariner Outboards 2 May 5th, 2003 03:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
