MY THROTTLE CABLE RIPPED APART IN THE CHESAPEAKE BAY, I BOUGHT A NEW ONE AND PUT IT ON MY 17' WHALER... NOW THE WARM UP LEVER DOES NOT WORK ? ENGINE RUNS IN NEUTRAL AT HIGH RPM? WHAT DID I DO WRONG , WHAT CAN I DO TO FIX IT?I THINK IT IS JUST AN ADJUSTMENT, BUT WHERE? I TRIED ADJUSTING THE TROTTLE CABLE AT THE ENGINE ?DALE T.MCKESSONDALE@COMCAST.NET
i LEFT THE SECOND CABLE ALONE WHEN I TOOK IT APARTI CAN SEE IT IS SWITHCING GEARS OK IT JUST IS IDELING IN NEUATRAL WAY TO HIGH.... WHEN YOU PUSH THE THROTTLE CONTROL FORWARD IT CLUNKS IN TO GEAR BECAUSE IT IS IDELING SO HIGH????DALE
