  #1
Old August 20th, 2003, 05:06 AM
Craig Williams Craig Williams is offline
Default testing overheat alarm on Mariner 30hp
Is it possible to test the overheat alarm on a mariner 30HP 1989 model. Not even sure it has an overtemp alarm ?
  #2
Old August 20th, 2003, 05:52 AM
Just Jed Just Jed is offline
Default Re: testing overheat alarm on Mariner 30hp
your engine should have one .If it is a 4 cyl look beside the top spark plug. If it is a 3 cyl it is beside the middle plug. If it is a 2 cyl I am not sure but there will be a wire leading into the cyl head near the middle or top. You really should get a manual for your motor as it is a must if you are doing your own maint. Acording to the manual with a 30-40 hp during normal operation the switch is open (turned off). The switch will close (turn on) when the temp reaches 182-198 deg F. The switch will reset back to an open circuit (turn off) at 162-178 deg.F. Place the switch in water with a thermometer and heat the water to 182-198 deg check with an ohmmeter when the switch trips and then check when it resets. Again; You Should grab a manual even if it is from the library.
  #3
Old August 20th, 2003, 06:21 AM
ta.....I'll check tomorrow. Does the motor have to be running or the ignition on for the alarm to come on when I force the circuit to close ?
  #4
Old August 20th, 2003, 06:38 AM
Sorry I should have mentioned. Switch should be removed for testing. Again; The manual. I dont mean to preach but you can get yourself into some mighty big messes doing some seemingly simple maint. without one.
  #5
Old August 20th, 2003, 06:52 AM
I'm still not with you 100% buddy.I can test if the switch is closing with a meter as you suggested, but I would like to test it in "situ" and actually have the contacts close and hear the alarm come on. My friend just cooked a brand new yamaha with a plastic bag he picked up on the intakes, which luckilly he had insured.Is the temp sender a screw out sort of thing or just a contact type setup to the head. Does the engine have to be running or the ignition have to be on to make the alarm operate or is it impossible to trigger the contacts by immersing in water while the engine is running if nessacary to make the alarm circuit active. (sorry for my ignorance)
  #6
Old August 20th, 2003, 07:49 AM
A bracket holds it in place . If you want to test the alarm and not just the switch just ground out the wire that leads to the switch to the block or other good ground such as the base of a spark plug with the key on ,engine off.(k.o.e.o.) ..Only other way that I can say is to purpously overheat your moter and that would be dumb.Your friends yam should have had an alarm go off and if it didn't the warranty should have covered it.
  #7
Old August 20th, 2003, 07:57 AM
Thanks for your trouble, sounds like it could be best to remove the sender/bracket, put it in heated water (above overheat temp) turn the key on and see if it goes into alarm.
  #8
Old August 20th, 2003, 08:17 AM
Thought about it a little further. If you were to remove the switch and have it hooked up to the proper wire as if it were under normal running conditions and place the switch into a billy can with water and a thermometer; heat it up, (k.o.e.o.) and check what temp the alarm goes off, that is the best I think you can get to actual situation .
  #9
Old August 20th, 2003, 08:20 AM
I think we ar in sync now just read your last after i posted my last
  #10
thanx again
  #11
Old August 20th, 2003, 08:23 AM
sure hope I was of some help .And you are more than welcome.
  #12
Old August 24th, 2003, 08:57 AM
trumanlake trumanlake is offline
If that is a single wire sensor, you could heat it up all day long and it would never set off the alarm! It uses the casing of the sensor for ground, once you remove it you have no ground.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 30hp Continuous Alarm TSoko Mercury & Mariner Outboards 10 October 1st, 2006 11:57 PM
Testing overheat alarm? tjhamms Johnson & Evinrude Outboards 2 October 3rd, 2004 04:52 PM
mariner 150 overheat alarm rocks Mercury & Mariner Outboards 7 August 21st, 2004 09:43 AM
Mariner 50HP overheat alarm McGurk Mercury & Mariner Outboards 5 May 13th, 2003 07:07 AM
Mariner 50 HP overheat alarm McGurk Mercury & Mariner Outboards 2 July 31st, 2002 09:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
