  #1
Old August 11th, 2003, 06:22 AM
cootersplace cootersplace is offline
Default How to change Mariner from starting off on 2 cyl.s
As I understand it , this 1993 115 hp. Mariner 4cyl will start off on 2 cyl.s till it hits 1800 rpm and then go to all 4 cyl.s Is there a way to eliminate the starting off on 2 cyl.s ? Thanx for the input . Cooter
  #2
Old August 11th, 2003, 07:03 AM
Spidybot Spidybot is offline
Default Re: How to change Mariner from starting off on 2 cyl.s
This is handled by a pretty enginious mechanical system, based on pressure in fuelsystem. It is not simple to disconnect, but ofcourse you can run hoses by it and have a constant feed to all four carburettors. I fear it may take some modification to the carbs as well as only the two upper ones are designed to work in idle.BTW: Why would you wanna change it?
  #3
Old August 11th, 2003, 08:03 AM
I am not sure why. But I have not run it yet , this motor has been sitting for 4 years and has approx. 75 hours on it , so its like new , but I am doing all this stuff like rebuilds on all carbs and water pump ,fuel lines , trim & tilt ,and now the stator . Any way friends of mine bought it new in 1993 and they parked it when it started not running right . So I thought maybe the reason for not running right could be this 2 cyl. thing . I don't know anything about this 2 cyl. thing . Thanx Cooter
  #4
Old August 11th, 2003, 09:28 AM
dilligafda dilligafda is offline
The operation of the 2+2 system is actually quite simple. The bottom carbs provide only enough fuel for lubrication, but not combustion until 1800-2200RPM. At that point, the throttle butterflys open the passages in the carbs that allow more fuel to flow and allow combustion for operation on 4 cylinders. Modification to idle on 4 cylinders would be difficult considering the engine is designed to idle on 2. Hope this info helps!
  #5
Old August 11th, 2003, 05:43 PM
dhud64's Avatar
dhud64 dhud64 is offline
I have a 98 model 115 Mariner, i am finding out now that it idles on 2 cylinders. It runs rough on these two cylinders and a carb job didn't help. I wish I had known this before buying it. It's the only thing on the boat I dislike.
  #6
Old August 11th, 2003, 06:27 PM
Maybe there is still something wrong with yours , its hard to think that they would put these motors out for that many years if they idle so rough, people would not have kept buying them I would think. Let me know if you find out something about your idling. Thanx Cooter
  #7
Old August 12th, 2003, 02:53 AM
My 115 Merc runs like a dream. Idles at < 1000 rpm all day long, never fouls a plug.A slight roughness can be detected the moment it changes to run on all 4, but it is amtter of seconds.I once found it rough running around 1200 rpm, but 4 new plugs solved that right away.This is yet another occasion to mention, that you need a manual if you want to DIY or just to know more.
  #8
Old August 12th, 2003, 06:12 AM
What year model is yours . And I wonder if the owners manuel has more info on the running of it, than the repair manuel ? Thanx for your input . Cooter
  #9
Old August 12th, 2003, 06:13 AM
The Marine Doctor The Marine Doctor is offline
If there is a roughness when the change occurs @ the time the 2 other cyl's cut in...get the accel pump looked at.TMD
  #10
Old August 12th, 2003, 06:41 AM
Mine is ´91 but the 2+2 system is the same.Got a Seloc and a repair manual and find them both pretty good on the subject. Remember when you tune it, that only the two upper carbs have screws for idle adjustment. As little as 1/8 turn can mean a great difference.I've seen a couple of those motors running rough and too low idle due to too rich mix.
  #11
Old August 12th, 2003, 09:07 AM
1.4 gallons of oil in the reservoir
  #12
Old August 12th, 2003, 12:43 PM
skier skier is offline
Getting these motors to run on 4 all the time is really simple. The bottom carbs don't have idle jets, the top 2 do. Just order 2 more top carbs (That have the jets) and replace the bottom carbs with top carbs.Craig
  #13
Old August 12th, 2003, 01:10 PM
Yez, rebuilding it to 4 x top carbs would do. I still do not see any reason, though.On mine the 2+2 does xactly what it's meant to: Saves fuel, makes idle-running better. It idles and runs any rpm for any period of time with no problems. You don't notice any vibrating, uneven run or anything. Just smooth.Starts in idle both when cold (squeeze bulb till hard + 3 times, turn (press and hold) key), and warm (just turn key).If you could get yours running up to specs I'm sure you'd forget about converting it.
  #14
Old August 12th, 2003, 01:55 PM
Mines not even on a boat yet , its been sitting for 4 years on a pontoon boat ( that I don't want or need ) so I might not can tell any difference between it or some others . I just did not like the sound of the 2 + 2 thing , but I guess if all is right then it will be ok. Thanx for all the input . I hope UU with the other one will get some adjustments to make his right. Cooter
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 115 - Pitch Change? tedder Prop Questions and Topics 3 July 5th, 2006 11:44 AM
1989 60 mariner change T/T dguyme Mercury & Mariner Outboards 0 May 15th, 2006 02:54 PM
impeller change on '97 Mariner 125 quantumleap Mercury & Mariner Outboards 5 March 12th, 2004 06:02 AM
93 Mariner 60hp impeller change. robe_uk Mercury & Mariner Outboards 4 February 7th, 2004 03:20 PM
82 Mariner 90 HP Impeller change out jamescody Mercury & Mariner Outboards 4 July 22nd, 2002 11:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
