zepplinswt
- Dec 27, 2002
- 9
Little History First:<br /><br />The motor was just recently rebuilt and when I got it back it was running really rich, and wasn't running very well at all. It was "douhle stroking" @ wot is what the mechanic told me that worked on it. He said it would go away after running the right oil:gas mixture. Anyways I talked to a certified Merc Mechanic and he said it shouldn't be doing this and that the carbs probably needed a little adjusting. So I gave the boat to a to him which he tuned the carbs and now it runs better at wot but it won't idle very well. When in neutral it will idle for a second the pop of few times and die. Same goes for when in gear but idling. It will stay running if above 1000 rpms. Is it the idle that needs adjusting or are the carbs running to lean? <br /><br />What is the correct rpm it should be at in neutral and in water? Thanks in advance.
