Re: Piston ring stuck in piston
I am assuming you have the piston out of the engine. I would suggest that an aggressive solvent used liberally (submerge it and let it soak overnight) would get it. If you've already done that, you might even try a solvent based paint remover, just make sure it is solvent based and not something with lye in it . The solvents are not going to hurt the aluminum (not the case with lye). The ring is stuck in there with what amounts to varnish (dryed gas gum and carbon). I don't know any brand names in Austrailia, but some of the spray cans of brake cleaner here use chlorinated hydrocarbons like perchloroethylene which is prettey aggressive but wont hurt the aluminum.
