  #1
Old August 4th, 2003, 02:12 PM
w00dy123 w00dy123 is offline
Default mercury 9.8 How much water should be comming out of the pee hole at idle
I recently purchased a 1984 9.8hp merc for my 12 foot sea knot. i had the impellar replaced but it still does not spit out hardly any water. How much water should be comming out at idle?
  #2
Old August 4th, 2003, 04:31 PM
fgbutler fgbutler is offline
Default Re: mercury 9.8 How much water should be comming out of the pee hole at idle
Should be a steady stream, although not a very strong stream. Should get stronger with RPM's.
  #3
Old August 4th, 2003, 04:46 PM
The Marine Doctor The Marine Doctor is offline
Blow compressed air through the Telltail. If that does not cure it there is a blockage somewhere from a torn impeller. You may have to remove the exhaust covers to clean out the passageways. OR When someone replaced the impeller they bent the water pipe and it no longer seals in the waterpump.TMD
  #4
Old August 4th, 2003, 07:24 PM
valint1 valint1 is offline
I purchased the same Merc '84 9.8 about 6 months ago and have the same issue. The tell-tale dribbles out at idle but perks up considerably under throttle. I replaced the impeller with no significant change. The next step is to replace all the o-rings, gaskets and seals in and around the water pump. Perhaps even the stainless impeller housing. And just maybe, the crazy thing is performing as designed --but it worries me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
No water from pee hole at idle 76gunner Mercury & Mariner Outboards 8 June 17th, 2006 01:55 PM
1996 Mercury 150-No water shooting from pee hole at idle boatman24 Mercury & Mariner Outboards 1 January 4th, 2004 12:36 PM
1887 force 85 hp water comming out spark plug hole shawnw Force & Chrysler Outboards 1 August 24th, 2003 11:54 AM
no water comming out of Pee Hole boaterntexas Mercury & Mariner Outboards 2 March 23rd, 2003 04:56 PM
No water comming from Pee hole at Idle Speedy Mercury & Mariner Outboards 3 May 28th, 2002 11:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
