hello everyone,<br />i am new to the forum and i hope someone can help me. i have a 1988 mariner 60 hp outboard that leaks what i feel to be an excessive amount of gas from the carb. this occurs when the motor is NOT running! the amount is hard to determine but is enough to cause oil rings on the water surface while i'm fishing and makes quite a mess in the drain compartment of my boat. i have had it looked at by (2) different marina mechanics and they both stated that it was normal overflow when the motor is in its tilted position. they have told me that the location of the leak does not have any gaskets or seals to be replaced and that some of the older boats do this. i have never seen another boat do this and i would like to take care of the problem if possible. if anyone has experienced this problem or knows of a fix, i would love to hear from you!<br /><br />thanks,<br /><br />mike
