  #1
Old August 2nd, 2003, 06:16 AM
rpmrpm1 rpmrpm1 is offline
Default Overheating in '95 Mariner 225 caused by Lower Unit Corrosion?
Plagued by overheating at higher RPM's on port engine (some heat buildup on stbd too.) Did usual: new thermostats, new water pumps, rebuilt pressure relief valve - no real help. Engine rigging unchanged since installed in 1995.Have seen internal corrosion at top of lower unit between water intake and exhaust passageways allowing seepage of hot exhaust into cool water intake. High RPM overheating fixed by patch. Suspect same problem now at different point in lower unit. Anyone with similar problems/experience? Engines well maintained -350 hrs. Want to consider this lower unit corrosion before removal of cylinder heads or power head - could get expensive.
  #2
Old August 2nd, 2003, 07:56 AM
The Marine Doctor The Marine Doctor is offline
Default Re: Overheating in '95 Mariner 225 caused by Lower Unit Corrosion?
You might be able to change the baffle that separates the two chambers....also when you reassembled the gearcase to the leg...did you silicone the top of the baffle plate? This is a must as exhaust will pass through to the water side and cause overheat problems as it messes with the water flow.TMD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Lower unit corrosion Frank Acampora Force & Chrysler Outboards 3 February 25th, 2007 06:30 PM
lower unit corrosion opti al Mercury & Mariner Outboards 7 November 23rd, 2003 04:00 AM
'95 Mariner 225-Lower Unit Corrosion rpmrpm1 Mercury & Mariner Outboards 0 August 1st, 2003 05:07 AM
Corrosion on Lower Unit Gordhawk Boat Topics and Questions (not engine topics) 1 May 18th, 2003 05:41 PM
Corrosion on Lower Unit Gordhawk Mercury & Mariner Outboards 1 May 18th, 2003 05:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
