New carbs, new spark plugs, compression checks fine in both cylinders. New gas tank, new gas line and new female fuel connector. Ran great all day. I had the motor off for about 40 minutes while I fished and it started back up again and "bogged out" and stalled when I gave it gas. I pumped the primer ball on the gas line and tried it again and it started and ran just fine. I was wondering if the problem could have been caused by a faultering fuel pump or something else. The boat had sat for 4 years before I took possession of it and had all the work done to the motor. Although it is a 1987 Mariner I had a marine mechanic tell me the motor was built by Yamaha for Mariner.
