  #1
Old July 24th, 2003, 06:28 PM
JCH55 JCH55 is offline
Default MARINER 40HP (1994) IGNITION PROBLEM
I AM TROUBLESHOOTING A STARTING PROBLEM WITH MY 40HP MARINER AND NEED HELP. I WILL POST AS MUCH INFO AS POSSIBLE SO WE DON'T HAVE TOO MANY REPLIES BACK AND FORTH.SPEC: 1994 MARINER 4CYL. WITH 16 AMP BLACK STATOR AND COMMANDER 2000 SIDE MOUNT ELECTRIC REMOTE WITH WARNING HORN.PROBLEM: CRANKS BUT WON'T STARTI HAVE A SERVICE MANUAL AND HAVE BEEN THROUGH ALL THE INGNITION TROUBLESHOOTING. HERE ARE THE DETAILS:GAS IS GETTNG TO THE PLUGS.THE FOUR COILS ARE NOT SHOWING VOLTAGE WHEN I TURN KEY TO START. THE KILL SWITCH IS SHOWING VOLTAGE IN THE ON POSITION AND NO VOLTAGE IN THE OFF POSITION. IT APPEARS TO BE WORKING OK. THE STATOR LOW SPEED IS GOOD THE STATOR HIGH SPEED TEST IS HIGH. THE TRIGGER TEST IS GOOD. THE STATOR OHM TEST ON RED AND RED/WHITE IS 87, I THINK THIS IS HIGH. THE BLUE AND BLUE/WHITE TEST DID NOT REGISTER AN OHM READING. THE CONTINUITY TEST TO THE COMMANDER POWER CONNECTOR WAS GOOD FOR ALL TESTS. IT APPEARS TO BE A SWITCH BOX OR STATOR PROBLEM.NOW FOR A BIT OF IRONY, AFTER PERFORMING ALL THESE TESTS, TAKING ALL THE WIRES OFF THE SWITCH BOX AND REPLACING THEM AND OPENING UP THE COMMANDER AND CHECKING ALL WIRING, THE SON OF A GUN STARTED . I NOW HAD VOLTAGE TO THE COILS. IT STARTED THREE TIMES AND I TOOK IT OUT FOR A TEST RUN, IT RAN FINE.I LET IT SIT OVERNIGHT AND WENT TO START IT AND IT WOULD NOT START , SAME PROBLEM AS BEFORE, NO VOLTAGE TO COILS.ANYONE HAVE ANY IDEAS ?????YOUR HELP IS GREATLY APPRECIATED!!!
  #2
Old July 27th, 2003, 09:53 AM
15GLSSport 15GLSSport is offline
Default Re: MARINER 40HP (1994) IGNITION PROBLEM
http://www.iboats.com/cgi-bin/ubb/ul...;f=29;t=008219 try this from a couple of days ago-I think it solved my problem...Good luck.
  #3
Old July 27th, 2003, 12:42 PM
Thanks, I will give it a try. One of the last thing I did before it last started was to check the continuity at the pins. I do recall a fair amount of grease on the pins. Maybe when I reconnected the pins, it allowed them to work for a short period of time. Next time up to the lake, I will spread the pins and remove some of the grease.I hope this works, like you I really do not want to throw money at the switch box or stator if I don't need to.Thanks for your help!! JCH55
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Mariner 40hp outboard ....beeping? KARENM Mercury & Mariner Outboards 1 September 16th, 2006 10:40 AM
40hp Mariner/Yamaha ignition problems PACERll Mercury & Mariner Outboards 0 March 24th, 2005 12:27 AM
Mariner 40HP Ignition Switch Xcusme Mercury & Mariner Outboards 2 October 28th, 2004 06:14 PM
1994 40HP Evinrude - WOT problem Loon Johnson & Evinrude Outboards 11 August 13th, 2004 02:04 PM
1994 Merc OB 150 Power-Tilt + Ignition Problem jedwards6 Mercury & Mariner Outboards 7 May 3rd, 2004 07:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
