  #1
Old July 21st, 2003, 12:58 AM
ukwebfx ukwebfx is offline
Default Mariner 40hp engaging Reverse Probs
Hi,I have a Mariner 40 aprox 1980 something.it runs like a dream in forwards but when i try and engage reverse it ether makes lots of grinding noises and the revs highle jumps in to gear and then will work ok in reverse that time. or it will go into revese smothly just aclerate and not engage the prop.Anyone come across this problem before.
  #2
Old July 28th, 2003, 03:41 AM
Default Re: Mariner 40hp engaging Reverse Probs
a friend of mine said to me that i need to check the cables, is this a possiblity?
  #3
Old July 28th, 2003, 06:18 AM
The Marine Doctor The Marine Doctor is offline
Disconnect the shifter cable at the engine.Push the Linkage all the way to the back of the engine. See if REV engages.Has anyone done some work to the Gearcase...may not have aligned the shift shaft properly.Check to see if the P/S bearing carrier is in place and not pushed back. There should be roughly 1/16 in of play on the shaft...if there is more then the brg carrier has backed out and must be replaced or tightend.TMD
  #4
Old July 31st, 2003, 03:36 AM
hi diconected the remote cables and if i hold the lever back as far as it will go it will work ok, but if i just levae it in reverse it grinds and screams, when pused and help it onlly moves about another 4 mm but this seems enough to engage reverse
  #5
Old July 31st, 2003, 04:45 AM
Spidybot Spidybot is offline
A one-lever remote is supposed to idle in neutral when the lever is in the very middle position (often vertical, held in place with a 'click'). When moving either forward or backward it should push/pull the gear cable first, then add throttle.Both directions should allow gears to engage completely before adding throttle and this is managed by cable/linkage adjustment (supposing nothing mechanical is wrong). I'd check all these adjustments first. If no improvement I'd check if the remote box works OK.
  #6
Old July 31st, 2003, 06:09 AM
erikleppe erikleppe is offline
The gear pin that goes into the lower unit once jumped of on my 40hp, but it was easily fixed with tightening the nut. But if the nut is not corectly adjusted on the rotary taper tap you might experience problems like yours.
  #7
Old July 31st, 2003, 06:21 AM
Its possible that the shifter cam and pin are worn in the gearcase...both are crucial for reverse. IF they are worn you will not have the correct travel to totally get into gear.Did you also check to see that the Brg carrier did not back out?Remove the Prop and look inside...there should be a large plastic or metal ring (NUT) See if you can turn it clockwise. If this is the problem...it will move the reverse gear closer to the clutch.TMD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Forward or Reverse gears not engaging parker1700 Johnson & Evinrude Outboards 1 August 7th, 2006 04:33 PM
66 650 reverse not engaging fully nos1013 Mercury & Mariner Outboards 9 May 18th, 2006 05:39 PM
Mariner 3Cyl 70 LU - Reverse not engaging Daibheid Mercury & Mariner Outboards 2 June 18th, 2004 05:13 PM
not engaging reverse steve5341 Mercury & Mariner Outboards 1 February 3rd, 2004 05:56 PM
Problem with engaging drive and reverse jathomps04 Mercury & Mariner Outboards 6 April 25th, 2003 07:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
