Please help! I owned a 1976 20HP Mercury for many years and it ran without problem. I loaned it to my brother and he left it behind at the bottom of a lake. I purchased a 1974 20 HP Mercury (reconditioned) to replace it and have had nothing but problems.<br /><br />I use the motor (or would like to) on the weekends only.<br /><br />I squeeze bulb and choke at first start. It seems to run fine - idles a little high but not too bad.<br />I leave without problem. I run wide open for about 10 minutes then the motor suddenly loses power or will die as I slow down. When I try to restart I have to choke - sometimes it fires and others it won't for awhile. when it does restart and idles down and I try to put it into gear it dies. This repeats many times until I am lucky enough to get it moving. Sometimes it will only run at low speeds and others the dying repeats itself. But as soon as I stop again the restarting issues repeat themselves.<br /><br />Please offer me any advice you have as I am at wits end. I have had it back to the place I purchased it 3 times now with no help. He always gets it running in the tank.
