Trailer lights
Fishhunter38
Not a motor question, but not sure where to ask it.<br />I recently picked up a smaller boat and trailer and need to change out the lights. Well went to Walmart and got a set of trailer lights and installed them. Pretty simple I thought a no brainer.<br />Well the problem is that all the lights work running, right signal, left signal except when you hit the brake all the lights go out.<br />Checked (with tester) the truck plug even tried the neigbors truck and same thing. <br />The new ground seems good. Any help would be appreciated. Thanks
JB
Re: Trailer lights
Hi, Mike.<br /><br />Welcome to iboats. :) <br /><br />The correct forum for your question is Trailers.<br /><br />I will move this there.
