Re: How to lift an Outboard Merc
hi i found you off iboats
i from hastings and i need to get a mercury flywheel puller i seen you posed on there in 2002
i have a 200hp mercury
now also found there a problem too i posted after i took off the fly wheel plate thwillat has all the bolts on it was trying to get under there
they told me i should mark it or put it on TDC not sure how i know for a boat engine
but why does it matter its a the cover will it not run when i put cover back on?
how will i know where to put it now?
mike
