  #1
Old June 28th, 2003, 06:29 PM
bandy bandy is offline
Default impellor 75 mercury 1994
is it as simple as removing 6 bolts to drop bottom unit? Is there no need to unattach a gear linkage?
  #2
Old June 28th, 2003, 08:11 PM
roscoe's Avatar
roscoe roscoe is offline
Default Re: impellor 75 mercury 1994
Shift rod must be detached. Best to have a manual to walk you thru whatever you are going to do.
  #3
Old June 28th, 2003, 08:14 PM
Walker Walker is offline
I think that Merc has a splined shift shaft and should just slip out. You must be sure the LU and upper shift linkage are both in the same gear when re-installing the LU
  #4
Old June 30th, 2003, 06:36 AM
sharkcat sharkcat is offline
put it in forward gear remove the trim tab noting where its position for reassembly, undo the nut that was hidden under the trim tab,undo the nuts at the base of the center section & pull the gearbox off.If you dont touch the shift lever or shaft the box should just slide back in .You may have to wiggle the prop to get the spline on the drive shaft to engage.good luck
  #5
Old June 30th, 2003, 08:44 PM
Thanks for the advice. Now Ive done it once it is no mystery. Was very simple and easy to understand now. The shift control is on a short splined coupling that slides together. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Mercury 200 Xri Efi robertinga Mercury & Mariner Outboards 0 August 16th, 2003 08:40 PM
1994 Mercury 40 HP bankshot Mercury & Mariner Outboards 4 February 21st, 2003 08:37 AM
MERCURY 20HP OUTBOARD IMPELLOR REPLACEMENT NENE VALLEY Mercury & Mariner Outboards 1 December 26th, 2002 01:34 AM
1994 Mercury 90 HP macknote Mercury & Mariner Outboards 2 August 31st, 2002 06:37 PM
1994 Mercury 200 EFI believe Mercury & Mariner Outboards 1 July 26th, 2002 02:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
