  #1
Old June 24th, 2003, 06:40 PM
kahuna kahuna is offline
Default 1989 twin mariner 200 cxl compression?
I have twin 1989 mariner 200 hp. When I bought the boat last year, the surveyor said the compression results were 130 to 135 psi on five cylinders on both engines but the sixth cylinder on the engines were 115 and 110. Do I have a problem and if so what should I do? Also the engines run rough between 1500 and 2000 rpms.
  #2
Old June 24th, 2003, 07:24 PM
dakk1 dakk1 is offline
Default Re: 1989 twin mariner 200 cxl compression?
KahunaStrange that both motors would have one cylinder a little low. Not too bad though. Could rings be sticking a little on those cylinders? I had a ring sticking on my Merc 150 and a decarb worked wonders. I used Mercs Powertune. Good Luck!
  #3
Old June 25th, 2003, 07:21 PM
Thanks dakk1. It is strange that the 6th cylinder is low on both, It's even stranger because the port engine has a new power head (less than two years old.) Could the sticking ring be the cause of the rough vibration at 1500rpm to 2000 rpm? By the way they are smoking alot also.
  #4
Old June 25th, 2003, 07:32 PM
kahunaI would do a decarb. This is just my opinion. Some believe in it some don't. It worked for me. It has been suggested to me that it should be done every 50 hrs or so and I think that is reasonable. If you think its been that long or longer give it a try. Since your compression is real close to tolerable it may bring those cylinders that are a little low up. Might help the smoking too. You'll need new plugs after. Good Luck!
  #5
Old June 25th, 2003, 08:51 PM
gss036 gss036 is offline
Do a SEARCH for DECARB and read the results. You may find a good answer is you search under member # 727 (DUNK), he post a lot and has a lot of wisdom on the subject.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1963 40hp Big Twin Low Compression Bollie Johnson & Evinrude Outboards 9 March 10th, 2006 05:34 PM
1989 225 compression johnnyvv2003 Johnson & Evinrude Outboards 9 November 27th, 2005 05:56 AM
1995 Mariner twin 6 hp vs 8,9.9 bfryer Mercury & Mariner Outboards 3 June 26th, 2003 01:38 AM
What should compression be 1989 Yamaha 200 hp?? bowhuntrrl Yamaha & Suzuki Outboards 2 March 30th, 2003 03:43 AM
Mariner 60 2stroke twin cylinder jimthesmith Boat Topics and Questions (not engine topics) 0 May 16th, 2001 12:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
