Re: Mercury 135 2-Cycle oil tank not refilling.
Merc's boat mounted oil tank is pressurized by the engine. If the cap/caps are not installed correctly and tight, it will not pressurize and replenish the engine mounted tank. As you describe, it's pressurized, so it must mean that the oil line is kinked or...??? Plugg'd??/ or ,,,, Remember, their are two lines from the tank to the engine. One is the pressure line and the other is the oil supply line.
