leaking antifreeze
JOEYBELL321
I recently replaced the gaskets on my 165 4cyl mercruiser thinking my coolant was leaking there.<br />However after completion I found it leaking from a factory hole in the timing chain circulating pump housing.I believe this tells me there is a leak in maybe the circulating pump and the hole prevents atifreeze from entering the oil.before I disassemble again Id like to be sure.thanx
rickdb1boat
Re: leaking antifreeze
You will get better results if you post in the "I/O' forum! Good Luck,
