  #1
Old June 16th, 2003, 10:20 AM
lazydawg lazydawg is offline
Default mariner won't idle in forward
I have a 1989 40Hp Mariner. It runs well at full speed and idles at stop fine, but it will not idle in forward. The motor just shuts off. It is a recent purchase (3 months) and the carbs were rebuilt professionally before I bought it. What should my first step be?
  #2
Old June 17th, 2003, 05:15 AM
Default Re: mariner won't idle in forward
  #3
Old June 17th, 2003, 07:02 AM
sharkcat sharkcat is offline
Your first step should be get a manual.I would then check float levels/needle & seats,reassemble,do a link & synch,then adjust idle mixture screws with the engine running in gear in the water.The problem you have could be the idle speed is too slow/the carbs are out of synch with the ignition/the mixture is too lean.Doing the above will fix it.Hope this helps
  #4
Old June 18th, 2003, 06:28 AM
I am new to outboards so pardon my ignorance. What do you mean by link & synch? I do have a manual that has already proven very useful. Thanks for the help.
  #5
Old June 18th, 2003, 06:54 AM
I should also add that it will usually crank right back up, but if you ease it into forward it shuts off. If you quickly go into forward and give it some throttle it will run fine until you back the speed down toward idle.
  #6
Old June 18th, 2003, 07:34 AM
Hi lazydawg a link & synch means adjust the ignition stops so the timing is right at idle & WOT,adjust the throttle stops so the carb butterflies are closed at idle & fully open at WOT,then synchronize the linkages so the ignition advances at the right time when you open the throttle.Your manual should have a section on adjusting linkages etc.Before you do this check the float levels & needles so you know they are right.If they are too high it can cause flooding at idle & too low can make the engine run lean not good for a two stroke.I know you say the carbs were rebuilt professionally before you bought the motor/boat...but rule #1 never assume anything.I had professionally rebuilt motor on my boat when i bought it.The link & synch was out,the float levels all over the place etc..So check it yourself that way you know its right
  #7
Old June 18th, 2003, 06:46 PM
Reelistic Reelistic is offline
I once owned an 83 70hp merc and experienced the same problem. My fix was to replace the stator... the low speed windings went T.U. Look in a service manual for the proper resistance readings for your stator.
  #8
Old June 28th, 2004, 04:51 PM
Blacksheep312 Blacksheep312 is offline
Hi, I have the same motor. I just need to pick up the idle a bit. Can you help me find the screw that will add more idle. Pictures would be nice too if possible. E-mail meblacksheep312@cox.net
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
97 mariner throttle in forward ,motor fails to unlock. oz57 Mercury & Mariner Outboards 4 April 19th, 2006 05:47 PM
Mariner 9.9 Stuck in Forward Cobrar12686 Mercury & Mariner Outboards 4 September 21st, 2005 01:04 PM
20HP Mariner half power in forward denbouy Mercury & Mariner Outboards 1 August 24th, 2005 06:31 AM
Random Klunking While In Forward Idle Sponge Bob Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 15 September 7th, 2004 06:09 AM
Update on my forward,forward and forward gears on '75 85hp Merc dkhntr Mercury & Mariner Outboards 0 June 5th, 2002 07:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
