  #1
Old June 13th, 2003, 12:32 AM
y2j y2j is offline
Default Mercury 650cc 1970 Shift linkage help... I don't know which ones which
I have to adjust the shift linkage towards my boat 3 or 4 turns so it crunches into reverse properly as now its just making crunching sounds..I twirled the top cable 3 or 4 times towards the boat.. But i don't know if i have to twirl the bottom one.. The top one which i twirled moves the distributor.. The one at the bottom seems to be bolted onto the shaft and moves something inside.. If i have to twirl the bottom one a couple of times to the boat how would i remove the bottom cable so i can take it out as i seem to be having trouble.. Can someone give me the exact procedureThanks again
  #2
Old June 13th, 2003, 03:14 AM
sharkcat sharkcat is offline
Default Re: Mercury 650cc 1970 Shift linkage help... I don't know which ones which
Hi Y2j first your motor is not 650cc it is a 65hp.The top cable is the throttle cable which controls the carbs & the ignition advance it will not make any diffference to your gearshift problems.The botttom cable is the gearshift cable if you follow it to the end there will be an 11mm nut which you can undo to remove the cable & adjust the barrel but before you mess with anything else get a manual they are essential to get things right.good luck
  #3
Old June 13th, 2003, 03:47 AM
wishinIwasFishin wishinIwasFishin is offline
g, day y2j I'm with sharkcat on this one Get a manual than you will know cheers Daryl
  #4
Old June 13th, 2003, 05:10 AM
y2j y2j is offline
but the engine capacity is 650cceven says it on the cowl and on my registration
  #5
Old June 13th, 2003, 05:11 AM
y2j y2j is offline
He told me this before.. He said the gear will click in easier on land then inwater with the pressure of turning the water.. and he said to try it out and if it crunches to give it 3-4 turns.. My reverse worked before its just he had to change this cable because the casing cracked
  #6
Old June 13th, 2003, 05:26 AM
g,day again the size of yours is 62.4 cubic inch (don't know the cc )cheers Daryl
  #7
Old June 13th, 2003, 06:29 AM
You have a mercury 650 redband in line 4 cylinder .The top cable is the throttle cable if you wind the barrel to far towards the boat you will bind up the linkage & it will be more dificult to get into gear.You should be able to get a piece of paper between the throttle arm & the stop screw & remove it without tearing the paper.As I said before the bottom cable is the gear cable there is an 11mm nut that you undo from the gearslide then adjust the barrel on the cable if its not going into reverse wind the barrel towards the boat.Get a manual libraries have them.If you dont get a manual & use it you will probably create more problems than you will solve.
  #8
Old June 13th, 2003, 06:36 AM
y2j y2j is offline
Thanks mate.. If anything screws up he willy fix it kindly hes a good bloke he doesn't like doing screwy jobs. But the reason i don't want to take it there is because its an hour and half drive away and i don't want to tow it that far.So i rather try myself and if lucky WOOHOO if not ill go for the ride..I gotta save a bit for a manual.. Cheapest decent one i found was about $100-$130
  #9
Old June 13th, 2003, 05:43 PM
echozulu echozulu is offline
hey guys if you disconnect the shift cable, tie up to the dock, crank engine dead idle, manually shift into fwd shift control to forward adjust cable to engine no problem but it sounds like your using those awful cable adaptors because mercury cables dont have stopnuts also you didnt mention if you had dual stations that model also had a reverse lock cam in the driveshaft housing made of plastic which when buggered up would cause all kinds of headaches they easy to change when you replace the impeller good luck bro
  #10
Old June 13th, 2003, 09:13 PM
Im sure you will be able to get a manual cheaper than that try secondhand bookshops.Im going to the library this weekend ill see if they have a manual for your engine.If they do Ill borrow it & scan & email the relevant pages to you if you post your email address.I used to own a 1971 650 merc that taught me alot about old engines & their problems.But I had a lot of fun making it work properly
  #11
Old June 14th, 2003, 12:53 AM
y2j y2j is offline
Well as it turns out when i looked at it.. It wasn't shifting all the wa only half way of the length when going into reverse.. So i unhooked it and gave it a couple of whirls and i tried to put it back on but i can't because the shifter underneath keeps springing down and i can't get the screw high enough through the cables end hole to get the nut on it to at least tighten it.Any tricks to making it easier. I tried the screwdriver to push it up from the side while my dad tried to stick it on but it was getting dark and our tummys were rumbling so we gave up for hte nightThanks guys Btw my emails holden@igreen.net and thanks mate for looking at the library i went to liverpool and they ordered the manual for me to but it could take a possible 2-3 weeks to get it to me from the Country's Main library full of archivesThanks for helping a teen
  #12
Old June 14th, 2003, 05:17 AM
RICKRICK1 RICKRICK1 is offline
Ensign
y2j--just below the cable is the bottom cowling, it should several small holes for drainage. Use a ice pick and go thru one of the holes from the bottom. On my 67 650 there is one hole almost right underneath where you need to push up on the shift linkage. hope this helps.
  #13
Old June 14th, 2003, 07:17 PM
y2j y2j is offline
Basically I got it and adjusted it as much as i could without loseing Neutral towards the boat..Well theres good news that I found another saga with the troubles i have been havingI have realised when i shift the boat in reverse and i go to turn the propellar by hand it moves both ways and does not make any clicking sounds like if it were in gear. I can move it forward, back whatever and it just keeps spinning freely. when i put it in neutral there is the slighest clicking sound you can hardly hear it but thats normal as i have heard it in my other now sold boats. When i put it in forward i can clearly hear it is in gearBut overall when in reverse no sound at all is heard as if it where spinning on a free axisI have got no clue
  #14
Old June 15th, 2003, 04:09 AM
y2j y2j is offline
bump
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My Motor goes forward/N/ but wont shift into reverse Mercury 650cc 65hp Thunderb y2jericho Mercury & Mariner Outboards 2 May 1st, 2003 04:16 AM
Motor and boat question. Mercury 650cc 1970 4 cyl 65hp y2jericho Mercury & Mariner Outboards 2 April 19th, 2003 12:29 AM
Mercury Thunderbolt 650cc 65hp 1970 has a water leak ;( y2jericho Mercury & Mariner Outboards 2 April 2nd, 2003 04:37 AM
Another Dumb Question.. Mercury 650cc 65hp 1970 Thunderbolt Question y2jericho Mercury & Mariner Outboards 2 March 31st, 2003 02:47 AM
1970 Mercury Thunderbolt 650cc 65hp 4 cylinder is it really 65hp? y2jericho Mercury & Mariner Outboards 3 December 10th, 2002 09:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
