I have a 1994 Mariner 125, 2 stroke, 4 cyl, that won't get over 2300 rpm at wot. The engine seems to run smoothly, just no power. It runs up fine when run out of water with muffs.
I think the fuel had been in the tank for a while. I have drained and refilled tank with fresh fuel, checked compression (Within tolerance all cyls). Replaced sparkplugs, have good spark on all cyls. Checked ignition system according to Mercury Manual. Everything appears to be within tolarances.
I am in the process of disassembling and cleaning
carbs and replacing fuel filters. (I cannot find a filter on the boat Alumacraft 185 Phantom). Can anyone give any suggestions on what else to check while it is disassembled? Any help would be appreciated. Joe
