Hi all. I've got a mid 70s 150 Merc L6 that is bogging out under load. If it's just me in the boat, it seems alright. I've checked or replaced the following with no improvement: All plugs replaced, distributor seems fine, I've rebuilt the fuel pump (gaskets, diaphram, check valves)checked the fuel line from tank to pump, compression is good across all 6 cylinders. The one thing that was odd was that I can choke out the engine by adjusting the idle mixture screws on the top and middle carbs but when I try the same thing on the bottom one, nothing happens. This prompted me to pull that carb and give it a good inspection and cleaning. Everything looked ok. Any suggestions would be greatly appreciated.
