  #1
Old June 10th, 2003, 07:56 AM
Ed.Ski Ed.Ski is offline
Default Mercury Tach
I have a 72 17' Slickcraft w/Merc 1150. I see a lot of posts about RPM's at WOT. The tach has been remove from the boat. Should I replace it? If so it looks like the Mercontrol has a tach socket in it. Can I get the plug to fit? Will any tach work?
  #2
Old June 10th, 2003, 08:02 AM
boating brad boating brad is offline
Default Re: Mercury Tach
yes, you should allways have a tachometer.
  #3
Old June 10th, 2003, 02:46 PM
daveanna daveanna is offline
The old mercontrols did have a tach terminal on the front of the control. Your control must be wired to your rectifier in your motor. If the rectifier is open you have no tach signal along with no alternator output. As far as I know only factory tachs will work. Also make sure your tach is set for 6 cylinder. There is usually a setting on the back of the gage. Safe boating, dgs.
  #4
Old June 10th, 2003, 02:51 PM
It's dgs again. The inline 6 cylinder mercs rpm range was 5000 - 5500. Try to run in the upper end of the range. Fyi if you didn't already know the spec. Good luck, dgs.
  #5
Old June 10th, 2003, 03:07 PM
Hooty Hooty is offline
Teleflex not only makes a tach that'll work for ya, they also make the wiring harness to plug into the receptacle in your control. Teleflex Accessories c/6Hooty
  #6
Old June 10th, 2003, 03:31 PM
Thanks for the info. Here is some more questions. The socket is 3 wire, 1 from the rectifier and a black & white from the key switch. I check a couple gauges and most have settings such as 2P, 3P, 4P, 5P, 6P, AND 4C, 6C, 8C. Do I need to know how many poles are in the stator? Is the tach picking up pulses from the rectifier?
  #7
Old June 10th, 2003, 06:17 PM
Yep.Here's the other Teleflex site. It'll tell ya all about it. Teleflex c/6Hooty
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Tach wiring. What goes where? w2much Electrics, Electronics and Trolling Motors 6 November 30th, 2006 11:13 PM
Mercury Tach NathanY Mercury & Mariner Outboards 6 October 29th, 2003 03:13 AM
Mercury Tach NathanY Mercury & Mariner Outboards 0 July 17th, 2003 10:42 AM
89 Mercury tach? ralphhotdog Mercury & Mariner Outboards 2 June 17th, 2003 11:30 PM
using an omc tach on mercury? crazyray Mercury & Mariner Outboards 4 July 14th, 2001 03:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
