  #1
Old June 5th, 2003, 03:06 PM
pete wylie pete wylie is offline
Default Mariner Dies At Full Throttle
Hi guys pls help.I have a 4hp Mariner (I think its a Yanaha powerhead),serial starts with 6EO.Bought s/h been in storage for 1yr. Origionally it would not idle without choke. I have stripped carbs and found blocked jets which I have cleaned and reassembled.It now idles and runs fine but at full throttle under load it dies and will cut out,it will restart ok and idle or go to 1/2 throttle any more and it will cough and cut out again.Any u guys got any ideas?
  #2
Old June 6th, 2003, 07:31 AM
sharkcat sharkcat is offline
Default Re: Mariner Dies At Full Throttle
Did you set the float levels when you cleaned the carbs?Could be too low causing fuel starvation at high RPM.Also check filters/pump etc sounds like you arent getting fuel.Did you clean the fuel system at the time you cleaned the carbs? If you didnt you might have got more crud in the carbs...Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25 hp merc. dies at full throttle trenfrow Mercury & Mariner Outboards 2 June 14th, 2006 06:11 AM
'92 40 hp Johnson, full throttle dies DrinkingEmu Johnson & Evinrude Outboards 7 May 27th, 2006 07:42 PM
79 johnson 9.9 dies at full throttle brokenjohnson9.9 Johnson & Evinrude Outboards 5 April 17th, 2006 07:31 PM
merc 140 dies at full throttle brunowren Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 1st, 2005 11:58 AM
197? johnson 7.5 dies at full throttle hambleton Johnson & Evinrude Outboards 1 June 15th, 2002 12:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
