  #1
Old May 27th, 2003, 09:49 PM
country boy country boy is offline
Default 175 hp efi mariner loss of power (1994)
hi, recently posted topic ,on this so not sure where to start so , my 175 was running ok then it seems that out of no where i am running about 5200 rpm to my spot ,it missed a little slowed down then took off ok then stoped for awile ,went to take off could not get up on step infact could not get over 1800 rpm, brought to shop ,.has had all the electronics changed and tested,mechanic said every thing checked out ok except (tps)set to specs did not fix problem,he said that i had some parts missin from efi a filter under cowl and soms trash may have got in injectors ,and said it would be more than it was worth to fix efi,susested that i convert to carbs ,is this something i should do ,what are pros & cons, or should i look into fixin the efi system, this is a certified merc dealer any input would be helpful . Than ks
  #2
Old May 29th, 2003, 10:42 PM
Default Re: 175 hp efi mariner loss of power (1994)
HELLO! ANYBODY ?
  #3
Old May 30th, 2003, 10:53 AM
jim dozier jim dozier is offline
I would get a second opinion from someone who knows how to work on an EFI engine.
  #4
Old May 30th, 2003, 11:02 AM
hello , thanks for reply was thinking about that but i brought it to a certified merc dealer ?
  #5
Old May 30th, 2003, 11:05 AM
If I go to a surgeon and he says my leg has to come off he might be right but I want to hear it from another doctor before I'll go under the knife.
  #6
Old May 31st, 2003, 10:59 AM
hello ,good point thanks ,that is why i bought this motor is the efi. C.B.
  #7
Old June 6th, 2003, 08:02 PM
hey ! found the problem it is a simple fix but very expensive , thanks for the encouragement ,brought it back to the dealer that first looked at it and had him put it overboard and he did more testing and found out my computer was fried not opening up the fuel swaped the ecu with one he had at his shop it pushed 4200 rpm against the trailer , ecu is very expensive to replace , C.B.
  #8
Old June 6th, 2003, 08:03 PM
  #9
Old June 6th, 2003, 08:05 PM
oops! my bad ,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Mercury 2.5L, 200 XRI Model 750 Power Surge/Loss at 1500 rpm KrisE Mercury & Mariner Outboards 3 April 9th, 2009 12:32 PM
power loss 1994 Johnson 115 HP shorttoe Johnson & Evinrude Outboards 2 July 20th, 2004 08:40 AM
1994 Johnson 225 Looper power loss beach nutt Johnson & Evinrude Outboards 1 May 30th, 2004 06:52 PM
1994 40hp Evinrude - Power loss at upper speed LuckyG Johnson & Evinrude Outboards 2 July 15th, 2003 09:57 AM
200 merc 1994 power loss shelbydriver Mercury & Mariner Outboards 3 May 13th, 2003 05:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
