  #1
Old May 26th, 2003, 08:32 AM
hewesmann hewesmann is offline
Default 1998 Mercury 3cyl timing off or ???
My engine seems like it doesn't want to open up. I've replaced the fuel pump and played with the prop pitch. It sputters a bit in the morning and sometimes sounds like it's hesitating a bit when going from 3500-5000RPM.......
  #2
Old May 26th, 2003, 05:34 PM
sharkcat sharkcat is offline
Default Re: 1998 Mercury 3cyl timing off or ???
Check the plug leads where they plug into the coil my guess is you have a bad connection due to corrosion clean it up & put it back together & use some petroleum jelly to seal the connection
  #3
Old May 27th, 2003, 07:32 PM
Will do. Also, Since posting I used an aerosole carbon cleaner you spray in the carbs while running, then sit for fifteen minutes, then run for 15. You would not beleive the debris that came out of the exhaust!!!!!Also, bought a timing light and found the timing to be at about 9 rather than 4.5. made the proper adjustments. Will post again after this weeked.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Timing Problem Mercury 60HP 1998 cmyers_uk Mercury & Mariner Outboards 3 March 13th, 2006 10:48 PM
72 65hp johnson 3cyl......could bad timing blowout a head gasket? FreeBase Johnson & Evinrude Outboards 1 August 12th, 2005 10:16 AM
timing for 1998 mercury 225 saltwater bslater Mercury & Mariner Outboards 0 June 23rd, 2005 08:36 AM
85 HP 3cyl timing question boat_ky Mercury & Mariner Outboards 0 May 3rd, 2004 04:33 PM
Johnson 25 hp 3cyl. 1998 Jon1448 Johnson & Evinrude Outboards 2 September 16th, 2001 04:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
