  #1
Old May 21st, 2003, 08:43 PM
badcop badcop is offline
Default 200HP Mariner, drives in idle/no acceleration
Hello,I have a 1985 200hp Mariner:In water, in gear it will idles around with no problem. Once you apply the lever/accellerator beyond idle there is no response. It will bog down alittle and eventually die if I dont back off on the trottle.I have tried the carb cleaner in carbs when applying more lever and at full throttle, but only thing it does is bog down more. Then back off on lever and idle around with no problem.Idle is fair, but not great.Any help would be appreciated.Have had ideas that it may be stator and/or trigger????Thanks,Cory
  #2
Old May 21st, 2003, 08:56 PM
Greg22 Greg22 is offline
Default Re: 200HP Mariner, drives in idle/no acceleration
BadCop,Try and push in on the key when you try and go. Also, might try and pump the fuel bulb. Is the fuel bulb firm? You need to check some fuel items before you start with electrical.
  #3
Old May 21st, 2003, 09:01 PM
wooleybooger1224 wooleybooger1224 is offline
i had this happen to me before, is the prop spun out, maybe not just a thought!
  #4
Old May 22nd, 2003, 05:14 AM
Yes bulb is firm, yes tried to push in key/choke.Prop spun??? I should add that out of water on mouse water ears, it accellerates, just when in water with load. I can also just throttle the boat while in water, without in drive and it throttles up.Carbs have been gone through, fuel tank removed and cleaned prior.Thanks,Cory
  #5
Old May 22nd, 2003, 06:56 AM
JB's Avatar
JB JB is online now
Ahoy, Badcop.Cleaned the carbs? How?Go to www.outboardrepairs.com and look up power loss. There is a lot of advice there for isolating your cause.Let us know what you find and what you did about it.Good luck.
__________________
RED SKY at night. . .
JB
  #6
Old May 22nd, 2003, 08:54 PM
Cleaned carbs, by soaking in industrial carb cleaner at motorcycle shop, then through degreaser, then carb cleaner, then air, and set float heights.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Carver Mariner V-drives (new Seacocks) KOT Carver Yachts 2 April 11th, 2007 08:32 PM
poor acceleration from idle mariner man 66 Mercury & Mariner Outboards 10 October 16th, 2005 08:15 PM
rough acceleration and idle special88 Johnson & Evinrude Outboards 2 May 27th, 2004 01:15 PM
60 HP Mariner dies on acceleration Buck H Mercury & Mariner Outboards 2 August 14th, 2002 09:40 PM
Merc 115 rough idle and acceleration ivdriver Mercury & Mariner Outboards 0 May 9th, 2002 06:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
