  #1
Old May 21st, 2003, 07:31 AM
CTFreeDiver CTFreeDiver is offline
Default Mercury gasket
  #2
Old May 21st, 2003, 08:54 AM
Kenny Bush Kenny Bush is offline
Default Re: Mercury gasket
The Carb float bowl gaskets will probably be OK. The Reed block will not. I have had to replace the little reed block gaskets on virtually every change. The carb baseplate/case cover will probably come off block clean. Anyway...... reedblock gaskets and your favorite sealant, along with some threadlock, and you should be OK....
  #3
Old May 21st, 2003, 02:01 PM
jim dozier jim dozier is offline
While I'm sure you could in some cases get by without using new gaskets, I wouldn't. Peace of mind is a wonderful thing in a boat away from shore. If you read enough of the posts on this forum, I bet 3/4 of them deal with a "problem" that somebody has already fixed,... just not correctly, and it takes days of investigation to figure out that the carb cleaning that was already done was inadequate or that the gasket on an otherwise proper carb rebuild is now leaking and the engine won't start or idles funny, or the piston went away for some strange reason. People will have differing opinions on this but gaskets are relatively cheap and I vote for all new ones.
  #4
Old May 21st, 2003, 02:34 PM
clanton clanton is offline
Before you buy the reeds, I would check on the jets may require a jet change.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 40hp Tracker Force by Mercury Gasket replacement Laddies Mercury & Mariner Outboards 0 June 24th, 2006 07:59 PM
Head Gasket at a Mercury Dealer? turtle1173 Force & Chrysler Outboards 2 August 14th, 2003 04:20 PM
Mercury 20 HP engine cover gasket Eagleclaw72 Mercury & Mariner Outboards 0 June 14th, 2003 01:02 PM
salt deposits on cylinder head gasket & water cover gasket mmas261 Yamaha & Suzuki Outboards 3 April 8th, 2003 12:10 PM
Torque for 1987 Mercury 80 HP water jacket gasket johnwood Mercury & Mariner Outboards 1 March 22nd, 2002 12:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
