I need some help/answers about a lower unit I recently acquired. It's off a 79 Merc 50 hp. Was hoping it would replace the LU on my 73 Merc 500, but am unsure. The round thing (bushing?) that surrounds the base of the shift shaft is different, it's flat with two grooves on the 79 LU...different than mine. Also the top of the drive shaft on the 79 is not tapered and has no spring nub on the tapered end. And finally, the water pump housing seems different...on the 79, the bottom half seems to be a metal casting? that looks like it isn't removable? Only the top half of the pump housing and impeller are the same as on my 73 Merc 500 (serial # 3,479,524). Don't know the serial number of the 79 motor. Will the 79 mate to my outboard leg all right? Do you remove the cast water pump housing (lower half) in the 79 when you rebuild the pump? Lots of Q's...but I am a curious George. Any answers appreciated.
