Re: Why does my primer bulb get soft and the motor run out of gas
If everything is brand new, it is more likely to be due to tank venting, as Bryan sugjested. There will be a small button on the fuel tank's cap (if it is one of those 6gallon plastic tanks).This must be opened to allow air to replace the gas in the tank as it is burned. The pump is drawing the gas it needs,and creating a vaccum inside the tank, but still getting enough fuel to run on.When you shut it down,the pump stops "pulling" the fuel it needs, and the vaccum it put into the tank,now sucks all the fuel out of the carbs and fuel line.<br />If you have a built-in tank,with no visable vent, you have a permanent vent,and it is probably plugged-up somehow.<br />To check this, try cracking the filler cap,so air can get into the tank.If it solves the problem, the vent is iether not open,or plugged up.
