  #1
Old May 15th, 2003, 03:35 PM
larry luckham larry luckham is offline
Default Mercury 115 cooling problem
I have a Mercury 115 inline 6. The original purcase receipt says it's a 1985. It's on an 18' Hydrasport that sits at my dock most of the time (saltwater). The boat get's little use during the winter, but the engine is kept tilted clear of the water.When I went out to check the battery and give it a try at starting for the first time this season I found that there was no water stream coming from the pee hole. Several people suggested that it might just be blockage at the pee hole. I followed their suggestions to check that with compressed air. I'm able to blow completely through the pee hole, the tube from the top cylinder and back through the fitting on that top cylinder right back to the lower unit.I don't have an exploded view of the lower unit and water pump, but it seems to me that air should not be able to pass freely around the impeller. That suggests the impeller has disintegrated.One other thing I noticed when I started the engine briefly a second time is that there is a stream of exhaust coming from the pee hole.Does the disintegrated impeller sound like the likely cause? Does the exhaust from the pee hole suggest something more serious? Is there a further diagnostic I can do to help isolate the problem before getting out wrenches?
  #2
Old May 15th, 2003, 04:46 PM
DJ DJ is offline
Default Re: Mercury 115 cooling problem
larry,Air would be able to go through the entire system.I believe your impeller is gone.
  #3
Old May 15th, 2003, 10:13 PM
Spidybot Spidybot is offline
The water jacket is separated from the exhaust to ensure cooling capacity around the head. A mix of water and hot exhaust bubbles would make proper water circulation impossible. The used water and the exhaust are mixed later in the circuit and emerged through the exhaust port/prop centre. At the point where the peehole is there should be nothing but water. If your impeller is dead things are not normal, though. Water does not circulate/fill the jacket and exhaust might make it's way to the pee.If there is no other signs of blown gaskets or leaks I'd replace the impeller with related fittings and expect it to be OK.
  #4
Old September 2nd, 2008, 12:41 PM
jwinslow jwinslow is offline
Question Re: Mercury 115 cooling problem
Just this weekend I experienced a similar problem. Water stopped comming out of the pee hole. Instead of water coming out, warm air came out with a slight component of blue smoke.
Once the engine started it would run fine for about 20 minutes. It then would show signs of loosing power. Also, white smoke or steam seemed to rise from the water in place of the usual thin light blue smoke.
I took off the coolant plate on the power head, and turned the engine over without spark plugs with the earmuff flusher with water running through it. Water gushed out of the bottom below the outside of the the lowest cylinder. I assumed maybe the gasket blew, so I replaced it, expecting to solve the problem. Replacing the gasket did not change anything. It seems that though water came up from the lower unit, there was not enough pressure for the water to make it to the top cylinder.
Also noticed whitish sludge coming out of bottom spark plug hole, when turning engine over without spark plugs.
I checked the compression. It was around 100 for each cylinder, while the engine was cold.
Any thoughts?
  #5
Old September 2nd, 2008, 02:45 PM
hourstonglascraft hourstonglascraft is offline
white sludge in #4 or #6 cylinder and a loss of power hmmm, i have had this a couple times the white sludge is water getting into that hole either from the exhaust gaskets or bottom crank seal , from what I know the water getting in only #4 or #6 indicates the bottom crank seal, be carfull dont run it to much like this or you will be like me with a blown up outboard
  #6
Old September 2nd, 2008, 04:19 PM
emckelvy emckelvy is offline
Water ingested into the engine, in concert with loss-of-water/circulation problems, is more likely due to bad exhaust manifold gaskets or a perforated exhaust baffle.
You'll need to remove the exhaust manifold cover for inspection.........ed
  #7
Old September 2nd, 2008, 05:25 PM
Chris1956 Chris1956 is offline
Larry, On that 115HP, water is supposed to mix with exhaust under the port side exhaust cover. Of course the water jacket should be full, and preclude the exhaust from entering it.
I would replace/rebuild the waterpump and see if the situation improves. if you still get exhaust into the water jacket, you may have a powerhead base gasket problem, or something.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 110 9.8 HP Cooling Problem or Not? imported_Deerslayer Mercury & Mariner Outboards 2 July 1st, 2006 07:19 PM
Mercury 4hp Cooling Problem imported_Mo_Tick Mercury & Mariner Outboards 2 July 21st, 2005 03:40 PM
Mercury 25M cooling problem Kitten Mercury & Mariner Outboards 1 August 5th, 2003 01:24 PM
cooling problem 7.5 mercury skint back Mercury & Mariner Outboards 3 April 21st, 2003 08:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
