  #1
Old May 14th, 2003, 01:08 PM
mercuryblues mercuryblues is offline
Default mercury electric start trouble
I have a 1966 mercury 650,65 hp,serial 1897689.I just replaced the control cables and went to try the motor out with the new cables attached and the electric start would not turn it over at all,it was if there was no power.I took the control box apart,(its a mercontrol if that matters,} and I have an ignition switch,a neutral safety switch,and an electric choke,and thats it but the cable hookups,where the wires,I believe there were 6,hooked to the ignition there were several that had broken insulation on wires and maybe that was my problem.Does anyone know how they would proceed with this,I called a merc dealer and was told that the switches mentioned above where not available he did not think.Any direction would be appreciated.Thanks all.
  #2
Old May 14th, 2003, 01:09 PM
Default Re: mercury electric start trouble
By the way the electric start worked before the new cables were put on
  #3
Old May 14th, 2003, 04:06 PM
12Footer's Avatar
12Footer 12Footer is offline
The wire problem is not unique to your old merc. It is the bane of Mercs of this vintage, and there is little one can do. Once the insulation has started to fail in one area, the entire harness can be expected to soon follow suit.I have used a "3M (tm) Scotchcast #82-A power Cable Splice Kit", and the old plug, and new generic 7-conductor cable 12gauge minimum (i used two lengths of 12/4 water resistant power cable made my Carol company, "P-7K 123033 MSHA)", but samey-same.You may luck-out and find a good one on ebay, but even the NOS harnesses (if you could actually find one), would be on the verge of loosing thier insulation.The Scotchcast kit is somewhat pricey, but nothing werks better that I know of.Of course, you could just hard-wire everything, if you have the skill and patience, and just elimminate the entire plug/socket do-hicky on the side.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #4
Old May 14th, 2003, 06:19 PM
is there a way to test the ignition switch? I unhooked the neutral safety switch and connected the one wire that did go to and from the N/S switch and I still have no power,no click,nothing.Its strange because it was working just fine.
  #5
Old May 19th, 2003, 03:45 PM
12Footer's Avatar
I would backtrack to the battery. This time of year, the terminals on batteries give us boaters untold grief,if we expose them to it.Remove the terminals from the battery, and clean the inside of the terminal and the outside of the posts, shiny. ceck the battery for 12V also.Re-assemnble, and try it.also, your control has a feature that prevents you from starting it in gear. But it would not "click" if it were the culprit.
__________________
right now."
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 40 HP Electric start M Mac Mercury & Mariner Outboards 1 February 28th, 2009 11:38 PM
Mercury 7 1/2 Electric Start perkdp Mercury & Mariner Outboards 0 May 4th, 2006 12:12 PM
1995-97 Mercury 25 hp electric start Greyelk05 Mercury & Mariner Outboards 3 November 15th, 2005 09:03 AM
electric start bad, Mercury 40HP 1978 suthman100 Mercury & Mariner Outboards 5 July 21st, 2005 06:33 PM
Tiller for 18 hp electric start Mercury outboard Californian Jim Mercury & Mariner Outboards 2 April 11th, 2001 09:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
