  #1
Old May 12th, 2003, 11:21 AM
McGurk McGurk is offline
Default Mariner 50HP overheat alarm
I get a HighTemp alarm only at WOT. New water pump. Lot's of water in the telltale stream. I opened the head and exhaust covers and water passages are clean. However there is no thermostat installed in the engine. Should there be one? Its a 1988 Mariner 50 HP 3cyl. S/N OB248535. Could no thermostat be the problem.
  #2
Old May 12th, 2003, 11:35 AM
jim dozier jim dozier is offline
Default Re: Mariner 50HP overheat alarm
Oooohhh! Deja Vu! I have a 87 Suzuki DT85 with a very similar history. I started with a new water pump and thermostat, but occaisionally my temp alarm would sound at WOT. I replaced a head gasket with a new factory design and removed a lot of blockages in the head from corrosion. I felt sure that was the cause. Now the "new" thermostat got stuck and I tried running it without one which helped for a while (winter the water was cold) but this forum convinced me to put it back in and when the water warmed up the alarm started sounding again. I removed the exhaust cover and cleaned out some blockages there and installed a temp gauge. Still the alarm sounded at about 190-200 degrees F. Aaahhh, but checking with the dealer I found that the sensor isn't supposed to cry until 237 degrees F. So I replaced the sensor and no more alarm. Hope this story helps.PS does your engine have a pressure relief valve in the head?
  #3
Old May 12th, 2003, 11:54 AM
No pressure relief valve in the head or anywhere else on this engine as far as I can tell. The temp sensor is OK and set for 240 degrees. I tested in boiling water and is stayed open circuit. Had to get it near the flame to get it to switch. I don't know who, why or when the thermostat was removed, but I think is should be used. No info about this in the engine manual other than how to test it on engines so equipted.
  #4
Old May 12th, 2003, 01:11 PM
Oooohhh! Deja Vu Vu again! I tried testing my sensor in a pot of boiling water also. But since water boils at 212 F mine would not trigger unless I stuck it on something hotter. The catch here was that it was supposed to go off at 237 F. and was going off somewhere between 212 F. and 237 F. Anyway I had already ordered the sensor since I didn't know what else to do and when I replaced it no more problem. My engine cylinder head runs about 195-205 F (as near as I can determine from the number on the temp gage) at WOT and a slightly oversensitive sensor was all it took I guess.I am guessing that your thermostat is missing because a prior owner ran into this before. I would put one back in and try to find what component of your cooling system isn't doing what it is supposed to do.
  #5
Old May 12th, 2003, 04:26 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Was it doing this before you replaced the impeller? If not you missed something on assembly or the impeller rubber may slipping on the hub. This hub slipping deal happened to me on a 140 Johnson. You didn't tweak the timing lately did ya?I know some cars will run hot without a tstat but never heard of an outboard doing it. If you continue to run without the tstat make sure you decarb often because piston crown crud builds up fast on cold engines...then the crud holds heat and burns little holes in the crown.
  #6
Old May 13th, 2003, 07:07 AM
The WOT temp alarm problem came first. I rebuilt the water pump twice so I don't think that I missed anything like an impeller slipping, but anything is possible. I've ordered a new temp sensor and will try that next.BillP, What is your thinking on the timing?. Could too far advanced cause this overheat issue? I'm not convinced that the engine is really going overtemp but without a gauge there is no way to know. The engine runs fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Buzzer/alarm - oil pressure or overheat - Mariner 100 , 1990 owlcritic Mercury & Mariner Outboards 2 November 4th, 2006 03:34 PM
87 50hp johnson Overheat Alarm Goldfish Johnson & Evinrude Outboards 5 May 10th, 2005 08:02 PM
mariner 150 overheat alarm rocks Mercury & Mariner Outboards 7 August 21st, 2004 09:43 AM
testing overheat alarm on Mariner 30hp Craig Williams Mercury & Mariner Outboards 11 August 24th, 2003 08:57 AM
Mariner 50 HP overheat alarm McGurk Mercury & Mariner Outboards 2 July 31st, 2002 09:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
