  #1
Old May 4th, 2003, 06:54 AM
dhud64's Avatar
dhud64 dhud64 is offline
Default Steering on Mariner 115
I have a steering problem that's got me puzzled. Steering wheel has a slight sticking problem when on the water, when ashore, the thing turns freely?Under the dash, in the steering control(?), there is a steering cable and another tube. What is that tube? I read on another post to fill that with penetrating oil. What do you think?
  #2
Old May 4th, 2003, 07:18 AM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: Steering on Mariner 115
No, that tube is for lube the worm cable to travel in. They are protected from most weathering by location.It is unadviseable to remove the cap and oil it, unless you see evedence of it having leaked (a spot on the deck under your helm). At least, look elsewhere first,then, go back to that if need be.you could lube it there, but run the risk of creating that oil spot in the monkey fur.Your problem is more likey, at the other end.The end of the cable runs thru a tube at the top of the transom clamps. Inside this stationary tube, is a shaft. One end is attached at the stationary tube, the other is attached to the motor. This assembly is the primary area of failure. It must be kept greased with a good quality marine grease at 80 hour intervals or less.It's a maintainence point, like the impeller and plugs.Un attach it at the engine, and unscrew the stationary end's retaining nut,and slide it out of the stationary tube. Use a shotgun bore brush with an old sock wrapped around it (for a swab),soaked in greased lightning, 409, Dawn Dishwashin liquid, or other detergent based grease cutter,to clean all the old grease out of the stationary tube. there may also be rust in there, but get the grease out, let it dry, then use the bore brush without the swab,to wire-brush this rust out.Ensure that the travel at the helm is effortless,one-finger operation. Next, try manually moving the engine port/starboard by hand, while you have the shaft out. It should move easily too. If not, you have problems at the hinge. shake it around, and see if there is any play at all. If there is, it's not good.Once you got it good and clean, reassemble while applying grease to the outside of the steering shaft, while someone else steers the cable port/starboard. Those two grease fittings are not there to lube this assembly, and the only way to lube this, is by this method, every 80 hours...Not the cleanest job, I know. Once you have marine grease completely coating the steering shaft inside the tube, go ahead and re-assemble the retaining nut, the felt and felt retaining nut, and attach it to the motor.give it a try.If it still hangs up, you may have to replace the steering cable as a complete assembly due to internal fraying.This is rare on even a modestly-maintained cable, but it happens.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old May 4th, 2003, 07:17 PM
dhud64's Avatar
Thanks 12Footer. I got that done this afternoon. I had a **** of a time getting the steering cable out of the tube. I found cruddy grease and there was some rust inside the tube, of which I removed most of it.Cant tell any difference ashore, other than it went back together much easier. I'll have to wait until next week to get it on the water and try it. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Convert Mariner 25 HP to remote steering Kaczki Mercury & Mariner Outboards 1 September 12th, 2006 06:25 PM
25hp Mariner Heavy Steering zdmaster2k Mercury & Mariner Outboards 2 May 3rd, 2006 10:22 AM
Steering Friction Screw on Mariner 5hp andymach23 Mercury & Mariner Outboards 1 June 14th, 2005 03:08 PM
20 hp Mariner steering arm. Ken Nasty Mercury & Mariner Outboards 0 November 10th, 2003 11:06 AM
Steering Trim on Mariner 25 hp way off. JohnTGardnerJr Mercury & Mariner Outboards 2 July 6th, 2002 09:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
