  #1
Old May 1st, 2003, 12:18 AM
y2jericho y2jericho is offline
Default My Motor goes forward/N/ but wont shift into reverse Mercury 650cc 65hp Thunderb
On the land sometimes my motor shifts into reverse and sometimes not but when im on the water it absolutely won't shift into reserve and just does this clicking or thudding sound like if it were trying to engage but can't stick it in. Its a 1970 Mercury Thunderbolt 650cc 65hp 4 cylinder model. No matter if i switch over from my 2 lower units it absolutely won't go into gear and i have no difference between the two.Is there something i can adjust myself because it just won't go into gear for some reason ;( Im kinda newbie and have no access to a manual for at least a fortnight till it comes through.. Beaching the boat is a ***** for me Thanks in advance guys-y2j
  #2
Old May 1st, 2003, 02:14 AM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: My Motor goes forward/N/ but wont shift into reverse Mercury 650cc 65hp Thun
Having a spare lower unit narrows it down to a linkage problem, (providing it's not the strange conincidence of both l/u's having the same blown gear).Have someone operate the binickle, while you watch the linkage at the motor.It's really the easiest way to understand the workings. It is all adjustable, as you will learn.The manual will explain it,I can explain it. But trust me, you won't fathom it until you study the movement with your own eyes.Not that it is strange or complicated. It's not. But---- "the thingy remains still,while the bracket thingy moves ,but only in forward"---isn't goin to help you as much.So you have your mate move the binikle into forward,slowly, exhilerate, then back to neutral, and past neutral in reverse to the stop, back and forth like this with the motor shut off, until you understand it. If the binikle locks-up,and doesn't allow engaging, turn the flywheel by hand until it moves freely back and forth. Then with your mate's help, you can see how it werks much better than the manual or I could explain.Where the manual will help, is when it comes to the proper meathod of removal and installation of the lower unit. It must be in neutral when it is removed, and the shift shaft must be in neutral durring installation. Insure that once the l/u is seated and bolted-up, that it is still in neuutral, and the cogs didn't slide into gear durring the mating-up process. If it is in gear, you must drop the l/u and start from scratch.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old May 1st, 2003, 04:16 AM
Will try.. Will try Also can a motor not shift into reverse if the Idle rpm's are set to low.. I have mine set to low right now its proabbly sitting at 300-500rpm when it should be close to 1000?Should i turn it up?THanks again guys
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp force wont shift into forward or reverse jhannan Force & Chrysler Outboards 5 June 10th, 2005 06:39 PM
Goes into reverse on land but not into reverse on water.. Mercury 1970 650cc Thu y2jericho Mercury & Mariner Outboards 5 May 12th, 2003 03:54 AM
Motor and boat question. Mercury 650cc 1970 4 cyl 65hp y2jericho Mercury & Mariner Outboards 2 April 19th, 2003 12:29 AM
Mercury 650cc 65hp Carby problem i suspect... y2jericho Mercury & Mariner Outboards 10 January 13th, 2003 06:40 AM
1970 Mercury Thunderbolt 650cc 65hp 4 cylinder is it really 65hp? y2jericho Mercury & Mariner Outboards 3 December 10th, 2002 09:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
