  #1
Old April 29th, 2003, 06:21 AM
jsmith55 jsmith55 is offline
Default 99 225 mercury, can turn flywheel one turn then it stops HELP!
First I thought it was a ground problem but then I tried to turn the flywheel with my hand. It will give one rotation either way and stop. I've droped the lower unit to see if the impeller was hung up, it seems okay. The lower unit seems okay. Nothing seems to be catching under the flywheel. I've taken all of the spark plugs out and checked to see if the pistons were moving, all of them move. The alternator is not stuck. What the heck else could keep it from turning? Please help.
  #2
Old April 29th, 2003, 06:47 AM
dkondelik dkondelik is offline
Default Re: 99 225 mercury, can turn flywheel one turn then it stops HELP!
mornin' js,If the fly will go at least 1 full turn, i'd drop the lower and look there.If she moves less the 1 full turn, might be bent rod. <EDIT> or a chunk of something (broke piston?) in a cylinder.Concentrate on the Power-Head. Can you pull the heads on this motor?Good Luck
  #3
Old April 29th, 2003, 07:04 AM
I was hoping I wouldn't have to pull the heads. I would like for that to be the last resort but now I'm running out of options. Thanks
  #4
Old April 29th, 2003, 07:07 AM
jim dozier jim dozier is offline
What happened the last time it was running? What have you done to it (if anything) since then. Did you just try and start it and it wouldn't start? Have you checked the starter bendix, it might be hung up. Is anything catching under the flywheel like a loose magnet or ignition part? Have you left any tools anywhere? Are there any screws missing near the intake system? Does it seem to move normally until it abruptly stops?Whatever you do don't force it until you know where the problem lies. This could be something simple or it could be terminal.It sounds from you initial description like something is catching something. The question is what and where.1. Check for external obstructions and obvious things.2. Check the starter drive.3. Pull the lower unit. You have apparently done that.4. Pull the flywheel and check underneath.5. Pull the heads and check the cylinders.6. Pull the carburetor and check the reeds.7. Pull the heads and check the cylinders.8. Pull the reeds and check the crank.9. Pull your checkbook and check your account.Good luck I'm hoping its something simple.
  #5
Old April 29th, 2003, 08:14 AM
I have not checked the intake, I will check that next and look for missing screws, bolts, nuts etc. I have not pulled the flywheel yet, but it doesn't look like there is anything caught. Yes it does come to an abrupt stop, I don't hear any rattling or rubbing noises. I hope I don't have to pull the checkbook!!! Thanks
  #6
Old April 29th, 2003, 08:24 AM
Oh, I forgot, last time I ran the boat, it ran fine, no problems or noises. Yes, one day it was running fine, the next day it would only make the single turn of the flywheel. (The starboard engine cranks fine.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
62' Evinrude Selectric Lark IV Wont turn off when you turn off ignition Homemadeboatowner Johnson & Evinrude Outboards 2 March 29th, 2006 10:00 AM
Flywheel tries to turn when I hook up the battery tom2 Johnson & Evinrude Outboards 1 August 24th, 2005 03:21 PM
Starter motor won't turn flywheel aweiss44 Mercury & Mariner Outboards 20 May 28th, 2004 02:09 PM
Starter will not turn flywheel. bigjohnallen Mercury & Mariner Outboards 7 April 21st, 2003 06:34 AM
Starter will not turn flywheel on 35 Johnson. Spenceror Johnson & Evinrude Outboards 0 March 30th, 2002 06:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
