  #1
Old April 24th, 2003, 05:41 AM
jathomps04 jathomps04 is offline
Default Mercury - Cooling System
I am using a 40hp Mercury 2 Cylinder 2 Cycle 80s Model outboard. I have inspected and installed a new impeller in the lower unit and water still isn't flowing from the exit hole up near the top of the engine. What can I check to try and fix this problem. Any help is appreciated.
  #2
Old April 24th, 2003, 06:04 AM
mellowyellow mellowyellow is offline
Default Re: Mercury - Cooling System
try blowing it out with compressed air, critterslike makin homes in there.good luck,M.Y.
  #3
Old April 24th, 2003, 06:05 AM
I have actually already tried doing that. Anything else I can do?
  #4
Old April 24th, 2003, 06:10 AM
jim dozier jim dozier is offline
Pull the lower unit back off and hook a garden hose up the coolant tube that comes out of the impeller and goes to the powerhead. If water doesn't come out the pee hole something is blocked. If it does you still have problems with the impeller.I just reread your post when you say exit hole are you referring to the pee hole or some other coolant discharge?
  #5
Old April 24th, 2003, 07:57 AM
tmcalavy tmcalavy is offline
before you tear the lower unit off again, put some muffs on it, take the top cowls off and start it up. my old Merc 500 won't piss until I push the rpms up a little, then it goes like a race horse. yours may be the same. before your run the rpms up a little, feel of the water jacket in front of the plugs. If it ain't cool to the touch, shut her down immediately and use compressed air to track down the problem. if its cool to the touch it will probably pee with higher rpms.
  #6
The pee hole.. Sorry
  #7
Old March 29th, 2009, 10:12 AM
Michael Coughlin Michael Coughlin is offline
Quote:
I also have the same problem ! i have a 115hp 4 stroke i cannot figure out how to get the water to flow out the top drain hole, the impeller is good and chased everything up to the block still no blockage , if you find out what it is please let me know . thanks
  #8
Old March 29th, 2009, 11:00 AM
ingydrummer ingydrummer is offline
If you have t-stats, it may take a minute to heat and open before you see anything.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 Mercury 135 Cooling System Spectrum Rider Mercury & Mariner Outboards 3 July 1st, 2006 12:14 PM
1979 Mercury 40 HP cooling system question r2376 Mercury & Mariner Outboards 1 June 19th, 2006 11:47 AM
FAQ : V6 Mercury Cooling System, draft achris Mercury & Mariner Outboards 11 July 12th, 2004 12:01 PM
7.5 Mercury outboard cooling system davidptp Mercury & Mariner Outboards 1 July 1st, 2002 04:10 AM
mercury sterndrive cooling system web4elk Mercury & Mariner Outboards 1 May 16th, 2002 12:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
